dial indicator mount using center valve cover bolt
Old 07-05-2005, 02:23 PM
TT_Vert's Avatar
Default dial indicator mount using center valve cover bolt
what size/pitch is the oem valve cover bolt? Im going to try to make something so i can mount my dial indicator on the center valve cover boss to measure lifter preload
Thanks
Dave
Old 07-05-2005, 03:19 PM
HavATampa's Avatar
Heh...you sound like me this weekend trying to figure out how to mount my dial indicator. I have this info at home and will post it this evening if no one else helps you out. I bought a Prothane fixture to use because I got tired of dealing with a magnetic base on an aluminum engine only to find out the fixture didn't come with metric adapters.
Old 07-05-2005, 03:25 PM
Restricted User
CAT3's Avatar
I believe they are 8mmx1.5px55mm. If not then its 1.25. Sorry, had to replace a lot of bolts, but that should be one of those.
Old 07-05-2005, 05:13 PM
ROCNDAV's Avatar
I believe it is a 6mmx1mm threaded hole. I will have to verify when I get home. As for mounting the indicators, I found a piece of steel plate. I then put the valley cover over the plate and marked the holes. I then removed the plate and drilled the holes.
Now when I want to check something, I place the place where the valley cover goes and use teh valley cover bolts to hold it down.
D
Old 07-05-2005, 05:24 PM
TT_Vert's Avatar
thanks guys. i just made a mount for the dial out of steel and bolted it to that using a rocker stud.
Dave
Old 07-05-2005, 07:31 PM
HavATampa's Avatar
Just for clarification. The rocker bolts are 8mmx1.25. Other bolt holes of interest for mounting dial indicators are the valve cover bolts 6mmx1.00 and head bolts 12mmx1.75. I used them all trying to mount my DI this weekend. Ended up using a piece of angle iron bolted to the head. Damned foreigners and their ****-eyed measuring system.
Old 07-06-2005, 11:45 AM
ROCNDAV's Avatar
The head bolts are M11x2. I was looking for a tap that size to clean out the holes before I found out a stock bolt could be modified.
D
Old 07-06-2005, 07:04 PM
HavATampa's Avatar
You're right, my bad. I should have known better. I spent the past weekend installing new heads and using my $50 APR thread chaser. I thought it was going to come gold plated, but it wasn't.
D
Old 07-07-2005, 11:20 AM
ROCNDAV's Avatar
Yeah, the suggested Kent-Moore tool is around $85-$125 depending on where you get it. It was much cheaper to grind a long used head bolt (like a tap) and use it as a chaser.
Quick Reply: dial indicator mount using center valve cover bolt
