Good mild cam for a DD
Old 07-16-2005, 04:04 PM
JAvenger007's Avatar
Default Good mild cam for a DD
Im looking for a really inexpensive cam (read-mild) thatll get me somewhere around 350rwhp with stock headers. Im just looking for a lid/catback/cam sort of setup. Can i do a cam swap for under $350 thatll get me a good 40 or 50 rwhp? I dont want my rear end busting and i dont want to sacrifice daily driving or mpg. What do you all recommend? Car is 99 M6 with just a lid and LM.
Old 07-16-2005, 04:20 PM
Jabroni's Avatar
Something with duration in the low-mid 220's and around .56X"-.57X" lift. If you want smooth idle, shoot for an LSA around 114-115. A 112 or so will give you a little more chop and the power will peak a little sooner in the power band. For instance, my cam is a 222/.566/112 and it's a baby cam by today's standards but it is a great, proven DD cam that's good for 10's in the right car. For what I do, I like it. There are sooooo many choices or I'd list some. Just take a look around. Personally, I don't think you can get a swap done for under $350. though. Good luck with your project.
Old 07-16-2005, 08:46 PM
d james's Avatar
the cheapest cam swap packages I've seen are from SDPC one of our sponsors, they can teak your specs, or you can just go with the grinds they have. They have a 220/224 551/551 114 LSA crane cam that sells for 308 plus you'll need the inexpensive LS6 springs that will last practically forever for around 50 bucks and of course another 45 bucks for the gasket set. So for around 400 bucks you won't find to many others that can beat that deal-at least I aven't found anyone else that can. I would pay close attention to cam lift numbers as well as its ramp rate which detirmines how soon the springs need to be replaced. Some cams need a replacement every 20-30 thousand miles. the crane cams should last quite a while, they told me using their springs 100,000 miles no problem, the LS6 springs with the above mentioned cam could last as long, but I'd check just to make sure, or replace them since they are so cheap in price. that cam should make a great DD as well. You could look into the LS6 cam some people are very happy with them as well
Old 07-16-2005, 09:33 PM
DONAIMIAN's Avatar
did you atleast read the sticky at the top of the section before posting. Its a lot of useful help. (dont mean to bust your ***** or anything)
Old 07-16-2005, 09:40 PM
LS1 Tech Administrator
Patrick G's Avatar
It's hard to get more than 30-35 rwhp gain with a cam when running stock exhaust manifolds. They're the choke point in the system. If you must run without headers, consider a cam that has less than 0 degrees of overlap at .050" lift.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 07-16-2005, 10:32 PM
NviouSS's Avatar
i picked up 35 rwhp with the LPE GT2-3 (207/220 .571/.578 118.5) on stock manifolds. only other mod at the time was a lid. i went from 316/343 to 351/350 after the swap.
Old 07-16-2005, 10:54 PM
dragonZ28's Avatar
The Thunder Racing 224/224 563/563 114 or 112 LSA is an awesome mild cam, and it makes power through all the RPM range. Nothing can really compare with this cam, IMO, for a mild cam upgrade, and it has a nice sound to it as well.
Old 07-16-2005, 11:03 PM
Fr33styL3's Avatar
agreed.
Price doesnt really matter with big or small cams.
If you need to pass smog, i think a 224 on a 114lsa is about as big as you can go.
