whats your thoughts on a custom cam
Old 07-20-2005, 06:22 AM
pdd
pdd's Avatar
Default whats your thoughts on a custom cam
thinking of maybe trying a custom cam to maybe fix this slug. or am i wasting my time
Old 07-20-2005, 07:57 AM
777's Avatar
I think you are wasting your time, because there is something wrong with your car that you need to find out before wasting money on another cam that, I don't see how, would fix the problem. Your car should be making well over 450rwhp, in fact, it should be making near 475+rwhp. So...you have other issues besides a cam.
Old 07-20-2005, 08:05 AM
LS1 Tech Administrator
Patrick G's Avatar
If you cam is on a 108 intake centerline, your valve events will look like this:
___________________________________________ 0.006 0.050 0.200
Intake Duration - ID_______________________ 283 232 152 F-14 INTAKE
Exhaust Duration - ED______________________ 287 234 150 F-14 EXHAUST
Lobe Center Angle - LCA (also known as LSA) 112 112 112
Intake Centerline - ICL____________________ 108 108 108
Intake Valve opens - IVO___________________ 33.5 8 -32 BTDC (- indicates ATDC)
Intake Valve closes - IVC__________________ 69.5 44 4 ABDC
Exhaust Valve Opens - EVO__________________ 79.5 53 11 BBDC
Exhaust Valve Closes - EVC_________________ 27.5 1 -41 ATDC (- indicates BTDC)
Exhaust Centerline - ECL___________________ 116 116 116
Overlap____________________________________ 61 9 -73 degrees
Ideally, you want to have your intake valve closing a little later and you want your overlap occuring closer to TDC. At 108 ICL, you are a little exhaust biased.
By retarding your cam 3 degrees (for a 111 ICL), you valve events will look like this:
Intake Centerline - ICL____________________ 111 111 111
Intake Valve opens - IVO___________________ 30.5 5 -35 BTDC (- indicates ATDC)
Intake Valve closes - IVC__________________ 72.5 47 7 ABDC
Exhaust Valve Opens - EVO__________________ 76.5 50 8 BBDC
Exhaust Valve Closes - EVC_________________ 30.5 4 -38 ATDC (- indicates BTDC)
Exhaust Centerline - ECL___________________ 113 113 113
If your cam was installed at 110 ICL (+2) then I'd say the cam is close enough to perfect and not worth messing with. You may want to look at other areas.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 07-20-2005, 08:17 AM
LS1Tech Sponsor
Slowhawk's Avatar
I would say forget the 400's and put a blower on and play with the 500hp #'s
Seriously,I could give you a list of stuff that could be wrong.Chasing the high dyno # get's expensive
Old 07-20-2005, 08:31 AM
777's Avatar
I think just about everyone is confused on his low dyno #'s (well low for what he has)
Old 07-20-2005, 08:41 AM
WS6FirebirdTA00's Avatar
patrick thats some good info right there. i have seen a few times on here guys go f13 to f14 and didnt make any more power or lost, maybe this would have to do with the icl you are talking about, f13 has less advance so would that bring it closer to ideal as opposed to f14? just been wondering if this could be why. anyway that info is good.
like 777 said, you may have problems that a new cam wont help with, or it could, or adjusting this cam like patrick said if its on a 112+4. i havent seen numbers with these heads you are using so i wonder if they have anything to do with it? maybe flow charachteristics arent optimal for that cam? have you called allan about this yet?
Old 07-20-2005, 08:46 AM
777's Avatar
I don't know, but He has had a few combinations and none of them have performed as well as they should have. Have you done a compression/leakdown test?
Old 07-20-2005, 08:53 AM
Grimes's Avatar
Hey pdd, are you still using stock injectors?
Old 07-20-2005, 08:58 AM
777's Avatar
That *could* be a problem, but many people have gone past his hp level with stock injectors. I would change them out if they are stock though (just to see if it helps, it can't hurt, unless you go crazy with the size). I have heard of a few people having trouble around 450rwhp with the injectors being maxed out. You will need for what you are wanting anyhow most likely. I never thought of that.
Old 07-20-2005, 08:59 AM
when i did my heads and cam i made sure i did it all, pump and injectors, dont wanna come up short. pdd who did your tuning did yu?
Old 07-20-2005, 09:09 AM
777's Avatar
Slowhawk did it IIRC.
Old 07-20-2005, 09:13 AM
ok so im sure thats in line
Old 07-20-2005, 10:51 AM
pdd
pdd's Avatar
i have 30# injectors-stock fuel pump. i havnt done a leak done test. the car and motor only have 6k miles on it. this sux. the cam is 112+4. maybe i need to drive it more i was thiking about retarding the cam 2 degrees, but i dont want to lose any midrange. the heads are 228cc, do you guys think thats too big for a 347 maybe?
Old 07-20-2005, 11:03 AM
pdd
pdd's Avatar
[QUOTE=Slowhawk]I would say forget the 400's and put a blower on and play with the 500hp #'s
QUOTE]
HA, i was thinking the same thing the other day. if i cant figure this out, i just might tear the whole thing apart over the winter
Old 07-20-2005, 11:12 AM
Wet 1's Avatar
The heads are your problem!!! Sell them to me cheap or I'll even trade you for a set of LS6 heads!
Old 07-20-2005, 04:29 PM
Super Hulk Smash
JakeFusion's Avatar
First, put a 300 shot of nitrous on the engine and blow it up. Then rebuild it with a forged bottom end.
Then try the MS3.
Or, just do the MS3, and if it's still acting up, see first part of post.
Seriously, pdd, did your car act up before adding the mods last fall? If not, start with that stuff. If so, repeat step one.
