Will 918 Springs Work with G5X4 Cam Thanks
Old 08-11-2005, 10:28 AM
WasteU's Avatar
Question Will 918 Springs Work with G5X4 Cam Thanks
LG Motorsports G5x4 608/610 lift
The Springs are comp cams 918
Old 08-11-2005, 10:34 AM
WildBills Toyota's Avatar
if you wanna rev high say to 6800 no. I would go with a double spring 100%
Old 08-11-2005, 10:38 AM
Derek98z's Avatar
don't skimp on the springs. Get some quality duals
Old 08-11-2005, 10:54 AM
PREDATOR-Z's Avatar
That is pushing a little, Comp 921, PRC "Gold" & "Platinum", or PP "Gold"
Old 08-11-2005, 10:58 AM
JZ'sTA's Avatar
It might work but I wouldn't trust it.
Buy a nice dual spring and let that be one issue you dont have to worry about.
Old 08-11-2005, 10:59 AM
masterdill's Avatar
You are kidding us right?
Old 08-11-2005, 12:01 PM
LS1 Tech Administrator
Patrick G's Avatar
The key to making the 918s work is shimming them to within .050" of coil bind. They should work very well if you do that.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
blkZ28spt's Avatar
Originally Posted by Brian@CompCams
I would run it all day long and spin it to 7,000. Wait a min..... I have! I'm probably the biggest fan of that spring.
What purpose do the 921's serve if you can run 918's to 7k on just about any cam out there for a stock cube LS1?
I knew the 918's were good, strong and popular, but damn!
Old 08-11-2005, 12:02 PM
SideStep's Avatar
OK... where is the cheapest place to get a set of these springs...
Old 08-11-2005, 01:27 PM
PREDATOR-Z's Avatar
Because you can see by this thread, that some people won't trust a single spring over a dual spring. That in itself (among other things)created a need in the market.
I've ran 918's on .612 lifts XE-R no problem. Unshimmed.
Perhaps correct geometry and lifter preload plays a huge role in when these need shimming.
Old 08-11-2005, 01:42 PM
masterdill's Avatar
The 918 will just absolutely not create enough pressure. Brian you scare me.
Old 08-11-2005, 02:11 PM
Patrick G's Avatar
They will if you shim them to within .050" of coil bind. Proven too many times.
Old 08-11-2005, 02:41 PM
PREDATOR-Z's Avatar
You are looking at pressure and pressure alone...THAT scares me. Take a look at the difference in valvetrain weights. With less weight you can control just as much if not more with less spring pressure.
That is true, true, true
Old 08-11-2005, 04:53 PM
dug
dug's Avatar
Thats because Comp Cams released some faulty 918's that broke. Leaving some people with junk engines after the valve dropped.
Dont get me wrong, I like the 918 springs but if they break youre pretty much fuckd.
Old 08-11-2005, 04:59 PM
slt200mph's Avatar
I like two instead of one in case one breaks..that is keeping it pretty simple..I see engines all the time that have broken valve springs and the damage that has been done .. ..you are in deep ca ca then..
Old 08-11-2005, 05:27 PM
00T\A's Avatar
I must say for a sponcer like Comp Cams to openly praise the 918's like this is pretty badass,especially when Comp offers a badass double set-up like the 921's,I'am impressed.
I must also add that i have over 15k on my 918's with a baby cam with no problems.
Old 08-11-2005, 05:56 PM
slt200mph's Avatar
Did you think he was going to talk bad about them..he works for Comp Cams man..if you ever take a look at a engine after a valve spring breaks you'll also be impressed
Old 08-11-2005, 06:04 PM
masterdill's Avatar
Will someone please help me here before a bunch of people really mess their stuff up after reading this crap?
Old 08-11-2005, 06:06 PM
00T\A's Avatar
I have seen a couple,Just thought it was cool the way backed his product
Old 08-11-2005, 06:16 PM
00T\A's Avatar
I also wanna say me personally would be more comfortable with a set of 921' with a cam that large.
