Ford guy with Ls1 dentonation issues, please help.
Old 08-12-2005, 04:44 PM
Bitemark46's Avatar
Default Ford guy with Ls1 dentonation issues, please help.
My wifes 01' (A4) was on the dyno a few weeks ago and the only thing it has is a TSP lid and Grantelli meter, everything else is stock. Well the a/f was a flatline 13:1 but I noticed like above 4500rpms or so I can hear a slight pinging. What can I do to stop this. I'm sure it's robbing some hp because of it. I thinking timing. Anyone? Thanks. -Mark
Old 08-12-2005, 04:51 PM
y2khawk's Avatar
Put the stock MAF back on.
Old 08-12-2005, 05:04 PM
Mr. Luos's Avatar
Does she run mid-grade??
Stock MAF as well.
Old 08-12-2005, 05:05 PM
Bitemark46's Avatar
Is that the reason? I thought since the a/f was flat and not high then how would the maf be the culprit? Thanks. -Mark
Old 08-12-2005, 05:41 PM
S1LV3R's Avatar
13:1 is good, but if nothing is done you would think the car would run fatter than that. My stock Z was in the 11 range at the top of the pull when it was stock.
Old 08-12-2005, 06:37 PM
Bitemark46's Avatar
Stock MAF as well.
Nope. 93 all the time. Everybody is saying that it's the MAF. I'll give that a shot. Wouldn't timing cause detanation before a lean mixture? Thanks. -Mark
Old 08-12-2005, 07:01 PM
Senior Member
Country Boy's Avatar
Thats one thing the aftermarket MAF does is jack up the timing some...
Old 08-12-2005, 07:33 PM
masterdill's Avatar
I swear by the stock MAF
Old 08-12-2005, 11:15 PM
Bitemark46's Avatar
Carl, get back to TR. How does the meter raise timing? I'm cornfused.
-Mark
Old 08-13-2005, 05:07 AM
Jimmy P's Avatar
How positive are you it was detonation? Hook up a scan tool like autotap or any other type of reader to make sure you are getting ineeded getting knock. Just switch back to the stock MAF either way. My car came with a Granateli MAF, and it went bad, so I replaced with it with another Granateli. I saw the way and changed it to a stock one a couple of weeks later.
Old 08-13-2005, 03:31 PM
Brains's Avatar
That MAF is ... "less than great" .. IMHO.
Put the stock meter back on.
