Can bad rocker arm adjustment cost me 100rwhp?
my recent dyno after all the headaches with tuning net 387rwhp...
I have heads and cam and that same combo netted on a camaro 484rwhp on an ls1 block... cam is 226/230 113lsa
Any ideas????
afr was from 11.6 to 12.2 at the end
the dyno wb was reading 10.6 to 12.6....
still, tuning will not net 100rwhp.
Any ideas????
We lost 98 hp due to the wrong spark plugs. They were too short and didnt even get close to getting into the chamber. It went from a little over 500hp to 600hp with the correct plugs in it. Just an idea. Yes a bad rocker adjusment could cost you alot of power, by letting the valve hang open.
I was told on another forum that i could have the wrong cam...
pre 02 cams where 19.7 base circle and laters where 19mm.. this is an 01 with an 04 engine ... if by some reason i have a 19.7mm base circle that is 27 thousands the valve is open... its still less than .050 but it should bleed off some of the pressure specially at higher rpms where i feel the car is loosing way too much..
www.roxanette.com/awfuldyno.jpg
What are the .050 specs of the cam you have in there now?
