Who's running cam only with Fast 90/90 setup and full bolt-ons??
Old 08-20-2005, 01:12 AM
1QuickT-A's Avatar
Default Who's running cam only with Fast 90/90 setup and full bolt-ons??
I'm probably gonna try this TSP 233/239 R2 camshaft with a ported FAST 90/NW90 Setup and stock heads... Will have full bolt-ons including..
Hooker LT's, X-pipe, Turndowns
Lid, Stock MAF, ASP Pulley
Built 4L60E, 3800 stall converter
Stock Rear w/ 3.73 Gears
Bigger Injectors, HPTuners
How well do you think this is gonna work? I don't personally know anyone around here that is running a cam w/ the fast 90 setup and stock heads. I know there are some guys on here that are doing this tho.. What kind of power can I look for? 380rwhp???
Suggestions are appreciated..
Old 08-20-2005, 06:50 AM
gtodoug's Avatar
I'd say closer to 400rwhp would be more accurate. I'm not cam only, but am running a smaller cam that what you are going to be running and an out of the box fast 90/90 setup and did the numbers in my sig, but have heads.
Old 08-20-2005, 09:36 AM
JS
JS's Avatar
Run more verter.....
Old 08-20-2005, 01:18 PM
1QuickT-A's Avatar
You also have a 6spd.. My car is an auto so it wont dyno quite as high..
Old 08-20-2005, 01:20 PM
1QuickT-A's Avatar
If I go with a big stall it will be too lose for the jug.. And this is my daily driver and I do alot of street racing. With a 3800 stall its already gonna be hard enough to get it to hook up on the street..
Old 08-20-2005, 01:23 PM
JS
JS's Avatar
Opps,didnt know u were running the jug...
Old 08-20-2005, 08:23 PM
Black8Banger's Avatar
I dyno 385hp/421tq with a 228/232 cam, 4L60E, 3000 stall, 10 bolt with 3.73s, LS6 intake, stock tb, stock injectors, LT headers, xpipe with single chambers and a lid. This is with the converter locked
You should be able to get 400 easy I would say.
Old 08-21-2005, 01:10 PM
1QuickT-A's Avatar
Thanks for the info.. I'm not gonna get my hopes up too high tho! I'm sure it will dyno pretty well. But, I don't know about 400..
Old 08-21-2005, 01:21 PM
blkZ28spt's Avatar
421 rwtq on a NA, stock headed, stock cube LS1?
Old 08-21-2005, 01:27 PM
Yep, surprised me to. It wasnt a freak number either, the 2 dyno pulls before that it was over 415
Old 08-21-2005, 01:32 PM
blkZ28spt's Avatar
Do you have a dyno sheet for this?
Old 08-21-2005, 02:35 PM
DanZ28's Avatar
I know of a M6 car in our club that did 420 rwhp with Trex and all bolt on's before 90/90 and 441 after 90/90. So the same setup in a locked TC A4 car should be in the 42x range I would think...
Dan
Old 08-21-2005, 02:39 PM
blkZ28spt's Avatar
Dan
Well, he is asking about a 233/239 which is a good bit smaller than the T-rex (9* each side) and I don't think very many people lock their converters to dyno. Many just aren't made to take that kind of abuse.
Old 08-21-2005, 09:32 PM
Brandon Boomhauer's Avatar
What happened to the PRC/AFR head setup?????
to hell...
Old 08-21-2005, 10:25 PM
1QuickT-A's Avatar
to hell...
Why do people feel its necessary to bring this up after its been dead for a month?? But, since your so concerned about it... TSP has the heads right now..
Old 08-21-2005, 10:30 PM
1QuickT-A's Avatar
Damn I never looked at his tq#'s.. That is very hard to believe..
Old 08-21-2005, 10:34 PM
blkZ28spt's Avatar
I'm waiting for a dyno sheet on that, I don't think it's possible. Something is messed up.
Old 08-21-2005, 10:39 PM
1QuickT-A's Avatar
I sure wish someone out of 50,000 members had a damn dyno sheet from a stalled A4 with a decent size cam and Fast 90/90 setup... lol
Old 08-21-2005, 10:45 PM
calongo_SS's Avatar
Nothing is messed up, he's just reading the converter flashing on the dyno as if it were a true torque reading. That's my guess anyway.
FWIW I made 385 hp in my A4 w/ the 233/239 unlocked, then 401 rwhp w/ the converter locked. This is w/ stock LS6 intake and stock 241 heads.
Old 08-21-2005, 10:47 PM
1QuickT-A's Avatar
Thanks for the info! Was this the older version of the 233/239 or the new "revised" edition?? What other bolt ons did you have??
