stock pistons
Old 08-23-2005, 05:42 PM
99hugcam's Avatar
Default stock pistons
The stock pistons don't have any valve reliefs or anything do they? If not, which I highly doubt they do, I am having problems.
At some point in the 58,000 miles on my engine, my intake valves made contact w/ my pistons. It almost looks like the pistons where flycut! Machine shop said the pistons would still be ok to use, but most likely all the intake valves are bent. The only point in time I can think of a situation where something like this could have occured was about 2 years ago when I had a dreaded 2-1 shift. If that is the case, I have done a cam swap since then, and when compressing the cylinders w/ air to swap valvesprings, nothing leaked?
The engine seemed to run good before I took it apart? Depending on the severeness of the bent valves, wouldn't I be losing ALOT of compression? Also, would the pistons still be ok? I don't see why not. Could it maybe cause a hot spot on the piston or something? Sorry for the long thread. Thanks for the advice!
Old 08-23-2005, 06:34 PM
99hugcam's Avatar
HEEELLLLLLLLPPPPPPPP Please!
Old 08-23-2005, 08:17 PM
greatwhite99's Avatar
I am in the middle of a rebuiild because of a mechanical overrev with the same dreaded 2-1 miss shift. I have a few divots in the pistons from this time as well as for the last time. Everything should be ok with the pistons but you should strip the heads and inspect the valves.
Old 08-23-2005, 08:20 PM
blkZ28spt's Avatar
Bump. This forum is getting an awful lot of traffic lately.
I think I'd be replacing valves....
Old 08-23-2005, 10:53 PM
99hugcam's Avatar
Old 08-23-2005, 10:59 PM
blkZ28spt's Avatar
Originally Posted by 99hugcam
I bumped it up. The forum has been getting a lot of traffic lately so topics are falling down to the bottom or off of the first page pretty quickly.
I then added that my limited knowledge on the subject would have me replacing the likely bent intake valves.....
Old 08-23-2005, 11:40 PM
99hugcam's Avatar
gotcha!
Old 08-24-2005, 08:42 AM
777's Avatar
I think I would be replacing the valves as well.
Old 08-24-2005, 09:04 PM
99hugcam's Avatar
Oh well, guess I'll have to jump on those patriot 5.3's!!!
