Trick Flow....
Old 09-02-2005, 06:30 PM
7 Second Club
Phil99vette's Avatar
Default Trick Flow....
Trick Flow Twisted Wedge 185 and 205s are on the way.....30 - 60 days out.
Phil
Old 09-02-2005, 06:39 PM
Wnts2Go10O's Avatar
?? trick flow makes heads for ls1's?
Old 09-02-2005, 06:40 PM
Wnts2Go10O's Avatar
also how can they be tw's if thats what the ls1 chamber actually is?
Old 09-02-2005, 06:46 PM
gollum's Avatar
Phil
Thanks for the very informative tech info. HUH Will these heads have their limitations like the AFR's because of the restricted airflow our plastic intakes offer including the Ported FASTintake?
Old 09-02-2005, 07:09 PM
Wnts2Go10O's Avatar
they willl prolly relase a r-series head after the "street" head. so be patient. i bet that 180 would make some ungodly torque though. the 205's might be half decent hp wise. trick flow is a very decent company.
Old 09-02-2005, 07:10 PM
Nate_Taufer's Avatar
just step up to a carb'd intake setup for efi.
Nate
Old 09-02-2005, 07:13 PM
Wnts2Go10O's Avatar
Nate
or sheetmetal...
Old 09-02-2005, 07:37 PM
7 Second Club
Yes but they are not advertising or released yet...
Old 09-02-2005, 07:38 PM
7 Second Club
The intake valve in their new design is moved away from the cylinder wall to deshroud the valve....
Old 09-02-2005, 08:00 PM
Wnts2Go10O's Avatar
?? the whole deal with the tw is well a a semingly twisted chamber. and the chambers that ls heads have are like that. thats why im confused.
Old 09-03-2005, 10:53 AM
66deuce's Avatar
the ls1 heads have common valve placements for all the different bore sizes(4.8,5.3,5.7,and 6.0)a compromise for production reasons.there's power to be had in moving the intake valve to a more optimum location.
Old 09-03-2005, 11:16 AM
Ed Curtis's Avatar
Cool
Phil
Are you sure Phil?
There are TFS LSx heads on the way but of the regular 15* inline valve variety... Unless the "boys" in Ohio are lying to me...
Ed
Old 09-03-2005, 12:01 PM
1QuickT-A's Avatar
TrickFlow needs to stick to the Fords...
Old 09-03-2005, 02:41 PM
3rdgenguy's Avatar
no they make a good set of heads for chevy's and summit racing owns them so i can drive only about 120 miles to there showroom by Ackron ohio
Old 09-03-2005, 04:04 PM
CRL 01 SS's Avatar
It'll be interesting to see how well the new Trick Flow heads work on LS1s. Does anybody here have Trick Flow heads on an LT1? I know they've had those heads out for a little bit now, and was just curious to see how well they work.
Old 09-03-2005, 08:30 PM
DavidNJ's Avatar
Once upon a time Chevy V-8s powered full-size Chevy's and intermidiates in very GM division. And in the smaller Nova when they existed. Right now, LSx are out on Corvettes, GTOs, SSRs, CTS-V and trucks. Once they were also on Camaros and Firebirds, but those are unfortunately gone.
All these heads are kinda overloading a limited market. How many heads can be sold?
And why doesn't someone break the bottleneck, and name a head intake pair; bypassing the intake port restrictions?
