How strong is the stock crank?
Old 09-03-2005, 03:30 PM
8 SEC SLOPPY SHOT!!!
tuff's Avatar
Default How strong is the stock crank?
Just as the post says how strong is the stock crank?I know how hard im on my motor with the bottle but what about the turbo cars that are putiing out big number are they stock?And how hard do you think you can spin one without failure.Is it worth buying a aftermarket crank with a short arm stroke.
Old 09-03-2005, 04:01 PM
Ferocity02's Avatar
I think the stock crank is the strongst part of a stock bottom end. There is forced induction Vette that is doing 790rwhp on the stock crank. However, I'd completely forge the bottom end by 600rwhp, including the crank. Its cheaper to replace the crank than the entire motor.
Old 09-03-2005, 04:12 PM
BlueSix's Avatar
The stock crank has been shown to handle over 1K RWHP (thanks Harlan ).
However, i don't know that i'd trust it much past 700 rwhp on a regular basis. Personally if i was going to be using a forged crank i would use that as an opportunity to increase the cubes a little
Old 09-03-2005, 04:54 PM
SS1875's Avatar
Lingenfelter has used them in their twin turbo packages with very good success. I have heard that they are good for 800-1000 HP. When in doubt, go forged.
Old 09-03-2005, 05:50 PM
cyphur's Avatar
they're good for quite a bit of power. i wouldn't go spraying the hell out of it or dumping 30#s of boost on it, but you can get by with many streetable setups on them w/o trouble.
Old 09-03-2005, 08:37 PM
EPP
EPP's Avatar
The stock crank has been proven to handle upwards of 1000 hp. I have yet to see or hear of one breaking. Bob
Old 09-03-2005, 08:47 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I'm probably making 900+ crank hp with my stock crank. Harlan probably made 1200hp with his but he was worried about it.
Old 09-03-2005, 09:08 PM
bichin95redta's Avatar
Both reference books I have on the LS1/LS6 have nothing but good things to say about the strength of the OEM crank. Just one of many quotes from both books:
"This cast crank is known to consistently handle over 500 hp naturally aspirated and 650 hp turbocharged in street engine usage-a very impressive amount for a cast crank."
Old 09-04-2005, 01:23 AM
y2khawk's Avatar
I didn't feel like pushing it too much farther. I was shifting mine at 8k rpm with the stock crank. Best of 171 MPH at 3350 lbs.
Old 09-04-2005, 01:28 AM
LSWannabe's Avatar
Speak of the devil.
Old 09-04-2005, 02:21 AM
liftin'em on nittos's Avatar
i'm building my first motor for my new setup (second motor will be NASTY) with a stock crank and a 2 stage carb plate that'll spray 600. if the right situation comes up i might see if she'll take the big shot. i've never heard of or seen a stock crank fail. there's so much other stuff that usually goes before it gets that far down.
Old 09-04-2005, 03:40 AM
DONAIMIAN's Avatar
AFAIK there hasnt been a stock crank failure to date.
Old 09-04-2005, 05:24 AM
Boostaholic's Avatar
Not due to raw power breaking it anyway
Old 09-04-2005, 08:42 AM
Benjamin Russick's Avatar
Maybe I'm just lucky, but I've been hitting my STOCK bottom-end with 575ish rwhp for a while now. IMO, the LSx bottom ends are pretty tough...
Old 09-04-2005, 08:49 AM
11 & 7 Second Clubs
Race Car Driver's Avatar
800 hp
Old 09-04-2005, 08:54 AM
tuff's Avatar
Seems like there is alot of postive coments about the stock crank.I just can't see spending the money if the stocker will do. Do you guys think it can take rpms upward of 8500?
Old 09-04-2005, 10:29 AM
that might be a problem tuff, i plan on taking mine to ~8,000rpm and that makes me nervous. i have one of the best engine builders around building mine and doing the research so it don't spit up. should be ok once or twice for 8500 tho.
Old 09-04-2005, 01:39 PM
tuff's Avatar
What crank have people been having good luck with.I see the eagles are like 800 bucks.I know the luniti are more money,is it worth the extra.I know some are wondering why im not just going to throw a big arm crank in it while im spending the money.I want the short stroke for nos
Old 09-04-2005, 02:11 PM
tuff, the long stoke will work even better with your "nossssss"
Old 09-04-2005, 02:20 PM
tuff's Avatar
Im looking to spin big rpms since nitrous likes rpms.With a big arm your going to pretty hard on the lower end.Plus big stroke = torque,nitrous makes torque so i think there is no need for the big stroke.
Quick Reply: How strong is the stock crank?
