408 cams. Best all around
Old 09-12-2005, 07:31 PM
Z'mnypit's Avatar
Default 408 cams. Best all around
What cam seems to be the most popular amoung you 408 guys? Ecspecially you that are spraying. Ive done a ton of reading & not sure which one I want to get. My CR will be right around 10.9-1, & I plan on spraying at least 150. This isnt an everyday driver so extreme doesnt really matter to me. I have a brand new F13 that im seriously thinking about throwing in there just to see what it does, I know its baby, but in the "smallest 408 cam thread" theres a couple smaller than that. It might sound stupid but its worth a shot. So post your cam suggestions.
Thanks in advance,
Vann
Old 09-12-2005, 09:46 PM
Restricted User
2001 Pewter WS6's Avatar
I have a Comp Cams 244/248 XE-R and I have been tuning it myself and I have it to when it has stock like driving manners until you mash the gas...
Old 09-12-2005, 09:51 PM
mr2guru's Avatar
TRex is a good DD cam for a 408
242/248 - .608/.612 - 110 lsa
Old 09-12-2005, 11:20 PM
SiL3NtXWS6's Avatar
I would agree that something in the 240/242 or 244/248 range would be best all around.
Old 09-12-2005, 11:23 PM
52172's Avatar
2001 what kind of numbers are you putting down with ls1 stage two castings? Looking into a similar setup maybe even an all bore 4.200 bore motor with stock crank and my ls1 heads that flow 299@ .600 306 @ .650 ?
Old 09-12-2005, 11:56 PM
Elite_Hot_Rod's Avatar
Same here, I have pretty much the same set up as you except mine goes thru a PG and a 9" spool, not street driven.
Old 09-13-2005, 08:15 AM
Z'mnypit's Avatar
Thanks for the replies guys, I was actually thing something in the 240 range would be right about right.
Old 09-13-2005, 09:58 AM
Restricted User
My heads flow 308@.600 I don't have any dyno numbers. There isn't a dyno close by. Soon as I get a chance to dyno it I will but I should have track times before that.
