How much compression is to much 4 pump gas
Old 09-13-2005, 12:12 PM
Phil'sC5vette's Avatar
Default How much compression is to much 4 pump gas
Title pretty much covers what I want to know
How much compression can I run with 91 octaine and how much with 93 octaine.
DO not include fuel additives
im looking for what you have above 11:01 how the car runs, any pinging, carbon?
and what heads you have ?
Old 09-13-2005, 12:26 PM
777's Avatar
I wouldn't run more than 11:1 with 91 and 11.5:1 with 93 octane.
Old 09-13-2005, 01:33 PM
do you have heads?
Old 09-13-2005, 02:05 PM
John02SS's Avatar
I'll be running 11.5 on 93 in good ol' Florida heat. I will be running a colder plug, running a better quench, and will have the fans on to keep cooant temps under control. I feel pretty comfortable at this compression, but I don't know how much more can go till you run into issues.
BTW.....forged pistons and TEA LS6 heads.
Old 09-13-2005, 02:23 PM
Blue Hawk's Avatar
It depend on the cam you run. The larger the cam, the more mixture you will bleed off at low rpm, the more compression you can run.
I'm running a 224/.560/112 XE with custom ported LS1 heads, milled .015 (64.2cc) for a 10.61:1cr.
I ran this combo for the last 2 summers without a single "ping". I think I could have gone with 11:1 but didn't want to take the chance with the crappy 91 octane we have here in Canada.
Old 09-13-2005, 02:24 PM
11 & 7 Second Clubs
Race Car Driver's Avatar
It depends on variables such as how much timing your are running.
Old 09-13-2005, 03:51 PM
Super Hulk Smash
JakeFusion's Avatar
As stated earlier, cam and timing and octane determine what you can run. You need to be concerned with dynamic compression (DCR), and keep that around 8.5:1. I'm sure you could run 12.1:1 or 12.5:1 on 91 octane with a huge cam. It would be such a joy to daily drive, though, that'd you be better off looking at 11.5-11.8:1 as the maximum CR and running a mid 230s duration cam to bring the DCR down to something manageable.
Old 09-13-2005, 04:11 PM
marine02ss's Avatar
I'm running 11.5c on 93 octane no pinging issues Good tune will help
Old 09-13-2005, 04:17 PM
11 & 7 Second Clubs
I run mainly 91 octane around town with 11.5:1 c/r at high altitude and with 27 degrees max advance. (I run 120 octane C25 in my 622 with 16:1 c/r and 29.5 degrees advance. trivia)
Old 09-13-2005, 04:19 PM
pewter 01 SS's Avatar
i have 11:1 comp and have no problems running anything from 89 to 91 octane.. dunno how much timing i have
Old 09-13-2005, 04:32 PM
This it the type of information Im looking for. Thanks guys
as for me, I have a TR224 .563 on a LSA 114.
I dont have my AFR on they, but they are at 60-61CC with a MLS gm Gasket
Old 09-13-2005, 06:04 PM
smask04C5's Avatar
phil, i'm running vette in sig in florida heat on pump 93, no problems 11.33:1 scr
Old 09-13-2005, 06:27 PM
I think you have a hair more compression than Ill have .
im glad to hear you have no issues
Old 09-13-2005, 07:04 PM
Restricted User
2001 Pewter WS6's Avatar
12.5:1 here on Sunoco 94 with 28* timing.
Old 09-13-2005, 08:24 PM
That's alot 12.5:01
I cant get 94 octaine
plus I need numbers on a 346 motor
Old 09-13-2005, 10:09 PM
JoeyGC5's Avatar
stock shortblock, MTI C2 cam, Patriot 6 liters with 59cc chambers and cometic gaskets. Rough calc for compression ratio is about 11.2 or so. I can run 91 -93 octane on 27 degrees advance timing with no detectable knock or pinging in 100+ degree weather.
Old 09-13-2005, 11:54 PM
TAQuickness's Avatar
As Jake mentioned - you dynamic comression is of greater concern to your motor.
Old 09-14-2005, 06:48 AM
mike c.'s Avatar
i run 11.2:1 on 93oct 30deg timing motor 24deg on nos.
Old 09-14-2005, 07:46 AM
I think the worst Ill have is 11.2:1
best Ill be at 10.9:1
10.9:1 is more where I wanted to be, but it looks like im at 11.2:1
Old 09-14-2005, 07:58 AM
Bill's 02 Z-28 SS's Avatar
Hi Folks
I am running 93 with a CR of 11:2-1 - you can look below to see what I have. The car runs well, no KR.
Bill
