Loctite on rocker. Forgot am i okay?
Hello yall i forgot to put loctite on the rocker bolts when i was reinstalling them. I drove a 130miles so far on the car without any problems and used all new rocker bolts. I also torqued all rocker arm bolts to 22ftlbs. Should i be okay?
Dam i been told that i should of used silcone sealant on the rocker bolts because of the ported heads i forgot that as well i hope i am not fucked. I torqued everthing to spec and the car runs good. I hope me not using loctite and silcone sealnt wont cause any other problems i really dont want to go back in there if i dont have to.
Thanks for the replys.I hope ill be okay then since its been done before without any problems. The car runs great so i think it should be okay and dont want to redo it again. And i am 100 percent sure i torqued all the rockers to spec 22fltbs.
Originally Posted by goober35
If you use loctite on your rocker bolts u have a greater chance of rounding off a bolt when u have to pull the rockers one.
For most ported heads, don't the rocker bolt holes go straight into the intake and exhasut ports? On stock heads the rocker bolt holes do not go all the way through to the ports; right?
I thought this is why you should ALWAYS use locktight in the rocker bolts for ported heads.
Since this is a 2 hour fix, I would rip off the valve covers and go with the locktight....
Ditto for the cam retainer plate and cam pulley....
Why take a chance.... just my opinion, however... ?
If indeed the rocker arm bolts do go through to the ports, then you will start burning oil.
(Correct me if I am wrong)
I always thought that loctit was need to keep the oil from "seeping" through the rocker arm bolt.
