best street use cam?? NO track
Old 10-07-2005, 10:44 AM
seadoo's Avatar
Default best street use cam?? NO track
im putting a LS1 in my 79 Z28 with a 6spd. but it will be pro-tour and will not see the track. what is the best street use cam that makes the best possible power ALL OVER the power range. btw, I am going with stage 1 LS6 heads for the extra compression.
thanks much
Old 10-07-2005, 10:46 AM
777's Avatar
I would get the f-13 (www.futralmotorsports.com) cam or the Tr224 (www.thunderracing.com) The f-13 will make a little more power and be harder on springs (probably good idea to change every 20,000 miles) The tr224 will lope a little harder. Either way I would get them on a 112lsa.
Old 10-07-2005, 11:32 AM
dug
dug's Avatar
I vote for the f13 as long as the car has at least 4.10 gears. If you want more off idle torque get the tr224.
Sharpe's Avatar
You want stop light to stop light power. You want the TR 224. Of course, you, like me, can control your RPMs, but the TR 224 starts its power band at 1700, and that's about where you'll be in town. Talk with Thunder Racing. I think it's Frutal Motorsports that makes the F13, for which you will receive a lot of reccomendations as well.
EDIT: oops, my post sat there for so long two people replied by the time i clicked on post!
Old 10-07-2005, 11:39 AM
RGR Pete's Avatar
I like my 224/228 *114 .563, good daily driver and very quiet.
Old 10-07-2005, 11:58 AM
luv2spd's Avatar
TR224 or smaller for a car that never goes to the track. This is considering if you have stock gearing....
Old 10-07-2005, 12:07 PM
Zach@Texas-Speed's Avatar
PM sent
Old 10-07-2005, 12:17 PM
Sharpe's Avatar
EDIT: Wrong company.
Old 10-07-2005, 12:34 PM
Derek98z's Avatar
That's a heavy car also. I would say a nice 220 TSP or some kind of 221 cam
Old 10-07-2005, 12:49 PM
98Z28MASS's Avatar
For a daily driver, I say T-rex! But seriously im putting an FM13 in my 98z28 and even though its not my daily driver I dont really get to the track and want it to idle decently and ive heard/been in a few cars with FM13's and if its tuned right it'll def idle great and provide tons of power for ya.
Old 10-07-2005, 12:52 PM
PREDATOR-Z's Avatar
Are you smoking that stuff again???
Old 10-07-2005, 01:02 PM
seadoo's Avatar
thanks man! Zach from TSP said a 224/228 on a 112 would be great for low, mid and topend power. which is good, so I dont have to down shift to get anywhere. and with the slightly ported LS6 heads (for the higher compression) i want, it should do fine!
so my mod list is..
LS1
LS6 intake
slight ported LS6 heads
224/228 .581 .588 112 (more than likely)
ported TB
aftermarket mech. speedo 6spd (damn, I wish I knew which one)
3.42's (maybe 3.73's)
hotchkis full TVS perform. suspension
4th gen center console
sport seats
Sebring Silver Metalic
black w/ chrome lip ZO6 wheels
it should run and look good!
still keep um coming though please!!
Old 10-07-2005, 01:25 PM
Hennytime's Avatar
hotcam, i got mine for 125 on this board, and with ls6 springs i never have to change ill be good till i get new heads (with a trex)
Old 10-07-2005, 01:34 PM
dug
dug's Avatar
Why run such tall gears? Get a least 4.10s. Even the stock cam likes 4.10s
Old 10-07-2005, 01:45 PM
99blancoSS's Avatar
Best street cam on the planet is the tr224 on a 112 lsa. No other cam beats its output bellow 5800 rpms. Show me one.
Old 10-07-2005, 01:49 PM
99blancoSS's Avatar
If your not at the track why run 410's??? wiht gas being as expensive as it is, no way in hell you should be putting 410's in a daily driver. With just 373's my gas mileage went down, alot. Where I used to cruise at 1400 rpms at 65 its now 1800 rpms and 70 or 80 just eats gas way to fast!
Old 10-07-2005, 02:06 PM
seadoo's Avatar
thanks for the comments... one last question, what kinda numbers do you think it will put down?
Old 10-07-2005, 02:31 PM
vettenuts's Avatar
I just installed a VHP cam for similar reasons, street only. Power peak is at 5,800 RPM and good torque down low. It has a 115 LSA as well so the idle is very good and with the Crane rockers and springs there is absolutely no sewing machine noise. All depends on what you are looking for in the can I think.
Old 10-07-2005, 02:34 PM
Moderator
davered00ss's Avatar
TR224. My gas milage only went down 1mpg when I put my 4.10's in. I had 3.42's before.
Old 10-07-2005, 02:48 PM
Moderator
JNorris's Avatar
IMO you cannot beat the TR224 114lsa cam. Enough cam for me to run low 11s and a few high 10s. All this performance with a stock like idle with no cold or hot starting problems when tuned properly. This cam is also easy on valve springs.
John
