LS2 Timing Chain identification/ dimensions
Old 10-13-2005, 10:02 PM
b727pic's Avatar
Default LS2 Timing Chain identification/ dimensions
Hey all,
In the middle of a cam swap, on my 2004 GTO with a build date of 08/2004. I forget the cutoff date...somewhere in 2004 all LS1's got the LS2 chain...or so I read on one of these forums.
Car only has 7,000 miles on it so I don't see the need to change the chain....assuming it is an LS2. I have seen the other posts...but without a side by side I am a little in the dark here.
Anyone know what the link thickness difference is? Or any other way to identify it?
Thanks
Old 10-13-2005, 10:33 PM
Dan_the_C5_Man's Avatar
I'm thinking the only way is to measure it.. Do you have a set of calipers? If you do, I have my old stock LS1 chain on my bench (can't seem to throw anything away) and I can measure the link plate thickness; you can then compare to what you have..
As an alternative, check out the pics in this thread. https://ls1tech.com/forums/generation-iii-internal-engine/391404-about-ls2-timing-chain.html They are accurate enough for comparison purposes. The LS2 chain links are quite a bit thicker, you should see the difference.
Old 10-13-2005, 10:53 PM
b727pic's Avatar
As an alternative, check out the pics in this thread. https://ls1tech.com/forums/showthread.php?t=391404 They are accurate enough for comparison purposes. The LS2 chain links are quite a bit thicker, you should see the difference.
I appreciate it....just went out to measure. I haven't pulled the cam gear off yet so it was a little tight...but here is what i get.
using dial calipers, the link plate next to the roller is approx .071
tomorrow I will have the chain laying loose for a more accurate measurement but I think this is pretty close.
Thanks again.
Old 10-16-2005, 07:49 PM
Thanks again.
Sorry to take so long to get back to you.. My stock inside plates on my old LS1 chain are approx. 0.045". So if I had to guess, you have the newer LS2 chain, no need to replace it.
Quick Reply: LS2 Timing Chain identification/ dimensions
