? about LS2 timing chain
Old Oct 7, 2005 | 08:21 AM
FSUNole17's Avatar
Default ? about LS2 timing chain
is the LS2 timing chain any different from the LS1? im almost 100% sure it is, but the reason im asking is because when i went to the parts departmetn to order one, they said that the chains are the same..... does anyone have an exact part # for the correct one?
Old Oct 7, 2005 | 08:25 AM
scottyballs's Avatar
here you go pt#12586482
Old Oct 7, 2005 | 08:31 AM
Katech_Jason's Avatar
LS1TECH Sponsor
Yes, it's the same.
12586482
Old Oct 7, 2005 | 09:30 AM
vettenuts's Avatar
The original LS1 part number was replaced with the LS2 part number as I understand it. If he looks it up, he probably only finds the new one. However, if you give him the original number he will probably see that it was superceded.
Old Oct 7, 2005 | 12:54 PM
Dan_the_C5_Man's Avatar
Absolutely NOT the same physically, probably the same part number (now) in GM's inventory.. Bottom line is, the LS2 chain has thicker end-plates, it's a beefier chain compared to what you have in the car now.. Do it. Order it w/ the LS2 part number if you have to.
Old Oct 7, 2005 | 01:25 PM
GuitsBoy's Avatar
The ls2 chain is the current replacement part number for ls1, ls6 and ls2 engines. When you look up "timing chain" for a 2002 trans am, it will give you the ls2 part number. Like the picture shows, its thicker than the chain youll be taking out of the motor.
Old Oct 7, 2005 | 03:30 PM
cyphur's Avatar
Originally Posted by Katech
Yes, it's the same.
12586482
not the same physical chain at all. much beefier and stronger. wouldn't put another ls1 chain in my motor if i had the choice of putting the ls2 chain in instead.
Old Oct 7, 2005 | 08:39 PM
ninobrn99's Avatar
****, and im about to do a h/c swap....wonder if i should do it.
Old Oct 7, 2005 | 08:49 PM
FUN LS1's Avatar
Definitely... the oil pump, too.
Old Oct 7, 2005 | 09:30 PM
ninobrn99's Avatar
dont have the money to go all out. gotta get other things too. otherwise i would be all over it!
Old Oct 7, 2005 | 11:17 PM
GuitsBoy's Avatar
Just replace the oil pump with a new stock pump and ls2 chain. Either port it yourself or dont even bother porting. Shimming is optional as well. Its a hundred bucks for the added piece of mind of a new chain and oil pump.
Old Oct 8, 2005 | 03:05 AM
CASHss99's Avatar
i was planning on getting the ls2 chain to... now does that come with the gears? or do you use teh stock ones or what..... and what are those part numbers and how much should cost?
will it work with f13 and dual spring setup?
Old Oct 8, 2005 | 03:55 AM
My 1st Love's Avatar
Just leave the old gears on there. The chain will come alone. Nice upgrade for 30 dollars. Best 30 bucks for piece of mind.
Old Oct 8, 2005 | 04:58 PM
CASHss99's Avatar
so there nothing wrong with using the old chain gears? i mean if the ls2 chain is bigger and beefier wouldnt u need the gear to fit it?
Old Oct 8, 2005 | 05:02 PM
GuitsBoy's Avatar
Nope, its the outer links of the chain that are thicker. They fit the stock sprockets just fine. Infact, I believe that the crank sprocket is identicle ls1 vs. ls2. The ls2 has a revised cam sprocket only because thats where the cam sensor is. Keep your sprockets. Ive yet to hear about them ever being worn past the point of re-use.
Old Oct 9, 2005 | 12:54 AM
CASHss99's Avatar
nice kuz i have 63k miles so im just making sure,, i hope the f13 and dual sprigs give me alota power
Old Oct 9, 2005 | 12:36 PM
FUN LS1's Avatar
I'm with ya... and I got 88k, and still beatin on it hard.
I can't believe the those stock springs, oil pump, and chain can still take !
Old Oct 9, 2005 | 01:28 PM
cowboysfan's Avatar
I'm sticking w/ (ls2) stock chain,so is ls2 oil pump better then ls1 and why ?
fuerzaws6
Old Oct 13, 2005 | 11:45 PM
Azrael's Avatar
N/M I answered my own question... lol
Old Oct 17, 2005 | 07:52 AM
ninobrn99's Avatar
well i ended up ordering one for Kris at SDPC. Great price!!!! maybe ill have enough for a oil pump too... not sure yet.
