how much $$$ to mill heads
Old 10-15-2005, 03:54 PM
P Mack's Avatar
Default how much $$$ to mill heads
I decided it would be stupid to leave my afr's at 66cc so I'm gonna get them milled locally. What is a good price for a machine shop to mill a pair of heads?
Old 10-15-2005, 04:00 PM
98UltraZ's Avatar
Locally (Manhattan, KS) I believe it was around $30 a head.. It might have been a little less that..
Old 10-15-2005, 04:17 PM
Boostaholic's Avatar
I can get it done for about $20 here, if not free. Friends with the machine shop guys.
Old 10-15-2005, 04:26 PM
P Mack's Avatar
Thanks for the responses, that's cheaper than I thought. I have a stupid question. When they mill heads do they have to disassemble them or is the milling done with the valves still in place?
Old 10-15-2005, 04:29 PM
xfactor_pitbulls's Avatar
You can do it with the heads assembled. Just make sure they are dry blow very well to get out all the shavings. Around $70 is the going price.
Brandon
Old 10-15-2005, 09:08 PM
Dmoney's Avatar
P Mack, where in S.A. r u getting the heads milled? I don't trust any one here in Laredo.
Old 10-16-2005, 02:06 AM
Jimmy P's Avatar
Make sure the shop is reputable and make sure they take off the same from each head. Even measure it yourself afterwards with a caliper.
Old 10-16-2005, 10:47 PM
P Mack's Avatar
I think i'll be going here http://www.kotzurracing.qpg.com/ . They've gotten some very good feedback on the local f-body and mustang boards.
Old 10-18-2005, 12:20 AM
wallstAL's Avatar
$100, disassemble, milled, washed and reassembled.
Old 10-23-2005, 12:09 AM
rhubar's Avatar
any where from 50-100. but make sure the shop is using a CNB manchine or better. If they say they use a rock-table or belt style, you'd better hope they have good experience on it. and a non-acid vatting would be best for cleaning the heads after milling. A lot of shops include this with milling.
