Quest to over 460 rwhp, Pretty close, what else?
Old 10-17-2005, 09:31 AM
MDoe8's Avatar
Default Quest to over 460 rwhp, Pretty close, what else?
Im heads/cam and all the boltons right now. My current power is 423/398. My goal is to be over 460 rwhp. What would be the easiest way there? I have most of a nitrous system at my house, should I just spray a 50 shot and shut up or should I get a bigger cam? My current cam is 224/228 .566/.566 112 lsa. I'm on the ls6 intake and granatelli maf as well. Any input would be great. If I do spray the 50 shot, do you think a whole new tune would be necessary? Thank you!
-Mike
Old 10-17-2005, 09:35 AM
z28C4maro82z's Avatar
BIGGER CAM!!!!!!!!!!!!!!! Then the spray then get yourself closer to hitting 500 lol
Old 10-17-2005, 09:37 AM
oange ss's Avatar
if you went with the juice it would only be there when you needed it , makin life easier on the motor...or you can get a bigger cam and have it all the time, but then you need a retune, dyno time and more than likely life will be a little harder on the motor, but the power will be there all the time without having to worry about how much is left in the bottle...i guess it's gonna come down to your personal preference......good luck
Old 10-17-2005, 09:39 AM
napoleon's Avatar
get the juice....while its open to dicussion, that big of a cam is undriveable for everyday driving...or even city driving IMO....but, again, thats up for debate. I would spend the 300 bucks and put together a nice custom kit on the cheap.
Old 10-17-2005, 10:09 AM
LS1 Tech Administrator
Patrick G's Avatar
A ported FAST 90mm intake and 90mm TB will gain you at least 20...possibly up to 30. Speed density tuning and no MAF would gain you another 5-10. Expensive, but there are no driveability downsides. In fact, with SD tuning, your driving pleasure will increase.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 10-17-2005, 03:31 PM
red00ta's Avatar
would he need to retune with a small shot ?
Old 10-17-2005, 06:24 PM
topfuelman's Avatar
Default SD Tuning
Really. Can you briefly explain the theory on the 5-10hp gain using SD alone? I don't understand where this gains power.
Thanks,
Old 10-17-2005, 06:36 PM
Patrick G's Avatar
In my case, the 85mm MAF was the biggest restriction in the entire intake tract. Even with the FAST 90 and 90mm TB, my MAP sensor would still show some vacuum readings at WOT. By removing the MAF and replacing it with a 4" pipe, my vacuum readings at WOT decreased and power increased. Restriction eliminated!
SD tuning also gives me a much smoother idle and low speed driveability with my current cam. Cams with lots of overlap make lots of intake reversion. This freaks out the MAF at low rpm. No such problems in speed density.
__________________
Old 10-17-2005, 06:39 PM
MDoe8's Avatar
What he said
