cam choice
Old 10-21-2005, 11:11 AM
IDZINE's Avatar
Default cam choice
I have an 02 WS6 M6 I am looking to cam in the next month or two. I have been looking at the thunder racing 224/224 but am undecided if this is the right one for me. I want a nice lope but still need a daily drivable car until I buy me another beater. I am planning on running stock heads for a while and upgrade to hardened pushrods and springs. I would like to produce around 420-440 rwhp is this the way to go or should I run something else.....I now have 350 rwhp on bolt-ons so I need something with a 75-85 hp increase .....any thoughts or ideas?????thanks ahead
Old 10-21-2005, 12:17 PM
joblo1978's Avatar
I don't think a 224 will give you those kind of numbers, especially on stock heads. It will give you a nice driving car though, just not those gains that I think your after.
Ever think about a 100 shot of nitrous?
Old 10-21-2005, 01:46 PM
T/A rocker's Avatar
That cam, maybe give 30-40 HP depending on other mods (headers, etc.) on the stock heads. You're gonna need heads AND a bigger cam to reach those numbers. and a good tune.
Nitrous, like IDZINE stated, is an option that might get you there.
Old 10-21-2005, 02:07 PM
777's Avatar
No cam that will fit with stock pistons will make 75-85rwhp more than your bolt-on car already has. That would put you at 425-435rwhp cam only. You DEFINATLY don't see that everyday. You will be in the average if you get 380-400rwhp from a cam only set up.
Old 10-21-2005, 03:25 PM
JBIRD02's Avatar
yeah, youre looking at about 390rwhp w/ that cam + all the bolt-on's and a good tune.
Old 10-21-2005, 03:33 PM
777's Avatar
That's on the high-average side.
Old 10-21-2005, 03:59 PM
JBIRD02's Avatar
yeah, youre right. I just figured he doesnt list a ported tb or ud pulley, so thats about 10rwhp, so I figure if he adds those, then he'd have 360, and that cam is worth 30rwhp, so 390 sounds about right.
Old 10-21-2005, 04:44 PM
Moderator
davered00ss's Avatar
I just installed that cam. Pretty tame. sounds almost stock. Nice kick in the pants though. You can defenitly feel the difference.
Old 10-21-2005, 04:53 PM
Z28_Ninja's Avatar
a 224 cam is nice but i would say for a m6 go with a 228 cam and it will be tame but give you better numbers than a 224 cam would. there is no way you would get over 400 with a good daily drive cam, they just are not big enough.
Old 10-21-2005, 10:11 PM
777's Avatar
umm an f-13 will net you over 400rwhp and it's one of the tamest cams out there that make decent power.
Old 10-22-2005, 12:06 PM
IDZINE's Avatar
who makes the F13 and what are the specs......
Old 10-22-2005, 01:49 PM
Greeny5005's Avatar
i am looking to do something similar with my car only i am looking to change the heads as well when i do the cam and i am not to worried about it being to rough of an idle or anything any suggestions to put me at 450 with all the supporting mods of course
Old 10-22-2005, 05:03 PM
Steve C.'s Avatar
MTI G1 Nice lope, fine for my daily drving needs. Then again im bias
Old 10-22-2005, 05:16 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Futral makes it. The specs I believe are 230/232 112lsa. I ll double check.
Old 10-22-2005, 05:17 PM
Lithium's Avatar
Yep.
Heres the link for you http://www.futralmotorsports.com/fms....asp?pf=1&pg=5
