H/C with 2.73 gears?
I have a 97 C5. I plan to install new heads (AFR 205's or the new Darts) G5X3 (or similar) cam, timing chain, and oil pump this month. I have Dynatech long tubes and a twin cone intake. I have 2.73 gears and a stock TC.
In you opinion, how well will it perform on the street with the 2.73's? What kind of 1/4 mile times can I expect?
Should I just go with the 3.42's and a 3200 stall? and if so do you think that will affect my cam selection? Thanks in advance for any advice.
LS1 Tech Administrator
Your car will be an absolute TURD with the stock converter and that big cam, regardless of how much gear you run. You have to understand, you're going to need a looser converter just to help out with your idle situation. See a G5X3 is going to want a 900 rpm idle. With the stock converter, any speed over 700 rpm is going to pull against the brakes. Can you imagine how hard it's going to be pulling on the brakes at 900 rpm?
Then there's the performance aspect. With 2.73 gears, you're going to be going 50 mph before the cam really starts making power. Most cars with stock cams will be 3 car lengths in front of you by the time you start making power.
You can keep the 2.73 gears (which I'm a big fan of BTW) if you get a good high stall torque converter. Don't go cheap here and don't get one that stalls too low. Ideally, you'll want a 4000+ rpm converter like a Yank SS 4000. If that sounds like too much, it's really not, but if you must go lower, I'd say you'll need to consider a different cam if you go below a 3500 stall.
Your choice of engine parts sounds good. Get your driveline up to par and you will fly!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Originally Posted by CBX
Thanks for the reply. Do you think the 2.73's with a high stall is the better way to go? Also, I thought the stock TC kicks in at around 1600.
Yes, the stock converter stalls around 1600, but the G5X-3 doesn't make good power until above 4000 rpm. That climb from 1600-4000 rpm is slow and painful with 2.73 gears and stock converter.
With a high stall converter, more gear is not as necessary. You'll get great gas mileage with 2.73s and your tranny will last longer because it will be rare that you do many 2-3 shifts at WOT. Do I think it's the better way to go? Not necessarily. More gear and more converter is typically better, but the converter is really the key component here.
LS1TECH Sponsor
i totally agree with patrick and just to add to what he said I have first hand experience with this HORRIBLE combination of heads/big cam/3500 stall/2.73 gears alot of bucking in 4th gear unless you work on it with a tune...i was tuned by a "pro" and still had a ton of it...wasnt until i set the converter to unlock right at the point where i was having issue that i was happy with it.
If you can't afford to do all of it now, eliminate the cam, heads, or gears. The converter is the absolute first thing you should do in your situation. I'm running 3.73's, 4000 stall and a big cam. It's a pretty good combo, not very easy on tires, but a lot of fun to drive.
I'd also like to add, that I was running a 3500 stall with a smaller cam than the g5x3, and it wasn't enough verter. I'd consider running a considerably smaller cam, or more converter. The 2.73's will be ok, not ideal, but not horrible. Also keep in mind that a high stall will feel pretty sloppy around town with 2.73's. But that is something that may or may not bother you. The gears will give a performance increase, and help with drivability. They'll help tighten up the stall, and keep the r's up a little more to help with any bucking problems.
I'm starting to agree with you on the hassle part. I've done 2 converters now on jack stands. It's not a whole lot of fun. If you can't get the verter done with the heads/cam, I'd wait.
LS1TECH Sponsor
i had my converter installed for $175...gears usually runs $250-350 for installation. Definitly try and match your converter to the cam you get...as stated my 3500 stall was way too small for teh cam i ended up with tsp231/237 so keep that in mind once your ready to plop down that $
Keep the 2.73s, get a 3500 stall and get a cam with more midrange power and less top end focus. The GX3 needs to spin pretty high for full advantage. Reduce the duration and tighten the LSA and you'll make good power in the rpm range that will work with those gears and a 3500 stall.
If I go with say a 230/236 112+2 LSA, with aftermarket heads and a 3500 stall (or more). Will this be a good match for 3.42's or 3.73's? Also won't it affect my tune if I add the gears later?
Tuning your car with a laptop is more fun than turning wrenches! You see big gains and don't get dirty.
That's still a pretty good size cam, but more in the daily driving, street/strip range. 3.42 gears would be very nice with a 3500+ stall. You'll need to re-tune for gears in the future because your shift points and converter locking speeds will be completely different. You need to save up for 2 tunes if you don't do everything at once. Maybe that will give you some motivation to buy your own tuning software.
