Comp Cams 875-16 "R" Lifters
Old 10-25-2005, 02:05 PM
APD*98SS's Avatar
Default Comp Cams 875-16 "R" Lifters
Horrific discovery today, 9 out of 16 lifters have no retaining clips and one was so bad even the pushrod seat was in pieces. I did a search on them after my discovery and all I could do was shake my head. The only light to this is most of the trashed metal was in the lifter valley, and was retrievable or at least so it seems. Also one broken valve spring on the number 1 intake.
Attached Thumbnails Comp Cams 875-16 "R" Lifters-tank00013-medium-.jpg   Comp Cams 875-16 "R" Lifters-tank00014-medium-.jpg
Old 10-25-2005, 02:57 PM
jub jub's Avatar
Sorry about your misfortune.
It seems the Comp R's are not what they are cut out to be! What lifter do you plan on using to replace them?
Old 10-25-2005, 03:05 PM
SAM98WS6's Avatar
sorry to hear dude..especially since some of us havent had any issues...what was your preload?
I hear Morel lifters are the ****....
Old 10-25-2005, 03:31 PM
Super Hulk Smash
JakeFusion's Avatar
The Comp 850s are fine and so are the Crane Replacement lifters. But yeah, Morel are the best.
Old 10-25-2005, 04:41 PM
dudas35's Avatar
Did you change the pushrod length?
Old 10-25-2005, 06:14 PM
APD*98SS's Avatar
7.400 on the pushrod length. 0.575 lift 230'/236' duration intake and exhaust, comp cams magnum rollers 1.75:1 ratio brand new GM LS6 block with the deck cleaned enough to true out, and nothing excessive. Motor hasnt seen 4500rpm because I was still building. Maybe 2k miles on the motor with frequent 500 - 750 mile oil changes... Motor built by competent engine builder. Absolutely no piston to valve clearance issues, I have not a clue? If I feel I got most of the metal out of the heads and liter valley area, how many of you out there would still drop the oil pan??? And will it be any easier with the BMR tubular k-member???
Old 10-25-2005, 06:17 PM
dudas35's Avatar
I thought you had to use shorter pushrods with these lifters.
Old 10-25-2005, 06:20 PM
APD*98SS's Avatar
If you look to the left of the #1 intake rocker arm, you can see a coil from the valve spring across the top of the ARP 12 point nut thst would be the #10 bolt head on the head torque sequence
Old 10-25-2005, 07:08 PM
SAM98WS6's Avatar
Preload?
Did you check the rocker travel over the valve? the one next to the broken one looks interesting..could be the angle though...
Old 10-25-2005, 07:48 PM
dudas35's Avatar
Sorry it wasn't shorter pushrods, it was adjustable rockers.
Old 10-25-2005, 07:53 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Lol, what was wrong with the stockers?
Old 10-26-2005, 01:39 PM
APD*98SS's Avatar
Anybody have a website for Morel Lifters???
Old 10-26-2005, 02:33 PM
cyphur's Avatar
Sponsor to the right ----->
I would also suggest Mellings lifters, a hell of a lot cheaper and still a great lifter. They can both be found here. Just scroll down the page a little. Morel can also be found @ Thunder's site, here.
Old 10-26-2005, 02:38 PM
ATLHwyRacer's Avatar
I've heard nothing but bad things when it comes to Comp R lifters.
Old 10-26-2005, 02:40 PM
cyphur's Avatar
I've heard mixed things. Lots of people say bad things, but I've heard some quite knowledgable folks say that when set up right they can be great lifters. Guess its hit or miss. Definitely not a plug & play DIY lifter tho. Go with the Comp 850-16's, or the Mellings for that.
Old 10-26-2005, 05:51 PM
ArcticZ28's Avatar
Ah, the Comp R's. Just one success story after another.
Old 10-26-2005, 06:42 PM
SAM98WS6's Avatar
Like reusing the stock rockers....
By the way..like what was asked before...what was your preload and did you check to make sure the pushrod length gave you the correct travel on the valve? If you didnt do either of these correctly then its operator error unfortunately and not the lifters fault. ..like so many other times here.
Old 10-26-2005, 07:34 PM
LS1 Swapper's Avatar
Seems more then odd to have a bunch of them broken, I'm running Comp R's without an issue, but I've pre-loaded mine much more then Comp recommends. I would assume the clips would be more likely to break due to lash since they would get pounded vs one's perloaded more, I still think Comp has their head's up their asses over this issue.
Many possibilities as to what would cause this, blaming one part because you've read about other issues on a forum isn't very scientific. Again odd to see multiple lifters broken.
Old 10-27-2005, 10:28 AM
Nasty N8's Avatar
I have had this same thing happen to 2 different motors. Not good. I will be using Morel from now on.
Nate
Old 10-27-2005, 11:57 AM
APD*98SS's Avatar
After extensive conversations with Comp Cams, they advised to replace the retaining clips with the e-clip style thats on most of their other lifters and on most race lifters. How irronic is that?
Quick Reply: Comp Cams 875-16 "R" Lifters
