A Look at Oil Consumption vs Driver Habits
Old 10-31-2005, 04:15 PM
Mr Incredible's Avatar
Default A Look at Oil Consumption vs Driver Habits
I read an article about how certain driver habits related to increased oil consumption. The Article Link. Can anyone comment from experience, either for or against this idea?
Since I have an automatic, I don't see the type of RPMs that were mentioned. Any thoughts?
Old 10-31-2005, 04:52 PM
quiksilver9531's Avatar
I would agree with that 100% if you do nothing but race your car your gonna consume oil
Old 10-31-2005, 06:24 PM
Camaro99SS's Avatar
I'm surprised the article didn't mention the revised PCV valve (it has no ball on the inside) GM released to help oil consumption. It helped on my car, but mine was never that bad, maybe a quart every 3k miles at most. Now it goes through maybe 1/3 quart at most, and with German Syntec, none. Mine also has some cold piston slap too.
Jason
Old 11-20-2005, 09:42 PM
gordonloser's Avatar
does anyone know the part# for the updated pcv valve that will help with oil consumption? Also, which synthetic oil should be used in the winter as opposed to the summer? Does it matter that I now have LT headers also?
Old 11-20-2005, 10:32 PM
LS1Z28_98's Avatar
I run mine fairly hard, and I used oil up and until about 50K mi. Since then, I havn't used any. I have 68K on it now, and have been using Mobil 1 or Red Line in it since 34K. I have no explaination as to why it stopped because my driving hasn't changed, I'd say it got harder as I have owned the car.
Old 11-20-2005, 10:40 PM
HOSS's Avatar
i use a lot of oil if i decel
Old 11-21-2005, 06:47 AM
BigDaddyZ28's Avatar
The part number for the 'updated' PVC is: GM12572717
And from my personal experience I will say that driving habits DO affect oil consumption... If I do not rev the car up over 3k a bunch it does NOT use any oil. It NEVER uses oil when the wife drives it... But when I take it out for a 'beating' and I am constantly seeing 4 or 5k, I can lose a 1/2 of a quart in an hour (or less time). I try to make it a habit to allways check the oil before I go out for a drive. I think the extra few minutes is well worth the money that It would cost me to fix it...
James
Old 11-21-2005, 09:13 AM
LS69TA's Avatar
Mine just started using oil since my last change. The car has about 54K on it. Never used a drop until this week when I gutted my cats. Maybe it's b/c I'm on the throttle alot more now, since it sounds alot better. It used a little over a quart in the last 700 miles ( I took a long trip this weekend). I may drive it easy for a while and see how it does, then try the new PCV valve if it's still doing it.
Old 11-21-2005, 10:10 AM
dudas35's Avatar
When i drive my car i lose about 1/2 a quart every 5000 miles. When my wife drives my car it uses a quart every 3000 miles or sometimes less. She loves to hear high rpms for some reason.
Old 11-21-2005, 10:45 AM
Var
Var's Avatar
that's a crap load of oil loss
Old 11-21-2005, 11:25 AM
JDM74's Avatar
It is all RPM related for my car. Drive it to the track and made 15 passes and it was a quart low. That was over a time frame of about 4 hours. Topped it off and made the 2 hour ride home. It used no oil on the ride home.
Old 11-21-2005, 11:35 AM
SUX2BU's Avatar
Yeah mine uses over a quart and a half a week. But i also drive it 90 miles a day, at 3500 rpms 50 min each way. It used maby a quart every oil change whn i had the M6.
Old 11-21-2005, 11:38 AM
LS69TA's Avatar
Damn you're turning some rpms. How much do you spend in gas each week? I'm going to baby it for a few days and see if the consumption goes away.
