measuring combustion chamber on the head
Old 11-07-2005, 04:21 PM
kumar75150's Avatar
Default measuring combustion chamber on the head
Is it possible to do with the heads attached to the shortblock?
I'm trying to calculate my SCR and I cant remember what the exact cc of the heads is.
They are LS6 castings that I am guessing are milled about .035. That should leave them right around 60cc correct?
Old 11-07-2005, 04:41 PM
WsSickLs6's Avatar
you probably shouldn't be guessing about things like this...call up where you got them from and find out
Old 11-07-2005, 04:54 PM
kumar75150's Avatar
well its not a life/death situation
if the heads are 60cc, my SCR is exactly 11.5:1
I am trying to get away with as much as I can since I have a pretty big cam. I wouldnt mind being near 11.8 or so. I'd change the head gasket but the heads are already on the block.
Old 11-07-2005, 05:00 PM
Brandon Boomhauer's Avatar
http://www.rbracing-rsr.com/compstaticcalc.html
what info are you putting in there?
as in bore, deck height, piston volum etc?
(just curious mainly, but searching for milled specs of ls6 heads might help)
Old 11-07-2005, 05:07 PM
kumar75150's Avatar
That one is either fubarred or I am not inputting the data correctly. I am using another calculator.
4.03 bore
4 stroke
.054 headgasket
4.1 bore headgasket
-9cc piston
-.005 deck height
60cc head
Old 11-07-2005, 05:09 PM
kumar75150's Avatar
searching got me that .006 - .008 milled is about 1cc
a stock ls6 head is about 64.5cc
that why i am guessing that .035 milled is around 60cc
Old 11-07-2005, 05:39 PM
I've always used that calculator kumar
-9cc is a domed piston over there.
enter it as 9cc and its 11.55 fo rme
with a 58cc chamber you get 11.82
Old 11-07-2005, 06:01 PM
kumar75150's Avatar
ya i was entering the piston as -9 like other calcualtors
but its all just a guess
if the heads are actually 62cc, then i am at 11.3:1 which isnt a big deal but might be leaving a couple hp on the table
Old 11-07-2005, 06:11 PM
you running a GM MLS gasket, new style?
Old 11-07-2005, 06:46 PM
kumar75150's Avatar
its a cometic and i'm pretty sure its the .054 compressed thickness
Old 11-07-2005, 06:56 PM
ah... well at least you got the #s right..
you wanting it to be higher?
run race/pump mix or something?
Old 11-07-2005, 11:20 PM
kumar75150's Avatar
with the cam i have, i could run close to 12:1 and get away with 93 octane
Old 11-07-2005, 11:31 PM
bleeding off alot of cylinder pressure?
specs?
Old 11-08-2005, 03:30 AM
kumar75150's Avatar
253/261 on a 113 if i remember right
