Has anyone ever tried to weld..
Old 12-07-2005, 01:03 PM
7 Second Club
Phil99vette's Avatar
Default Has anyone ever tried to weld..
Has anyone ever tried to weld the factory valve covers? Welding an A/n fitting or a spacer.
Phil
Old 12-07-2005, 01:06 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
They are pretty thin so watch your heat. I have thought about the same thing, but almost want a backup in case it doesnt react the way that I planned.
Old 12-07-2005, 01:13 PM
7 Second Club
I've welded thinner aluminum than whats on the valve covers, I am more worried about the grade of aluminum.
Phil
Old 12-07-2005, 01:15 PM
white2001s10's Avatar
Much easier to just epoxy it in.
Old 12-07-2005, 01:17 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
weld would look prettier. I don't know what the grade of it would be. are you gonna mig or tig this?
Old 12-07-2005, 01:19 PM
7 Second Club
I am going to tig weld the spacer to the valve cover. Looks like I may need to mill off the ridge on the lower portion that holds the spacer in place. It makes the spacer sit too high.
Phil
Old 12-07-2005, 01:22 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Yeah I was wondering how tall it was going to be all said and done.
You take any measurements of it?
Old 12-07-2005, 02:32 PM
93LS1RX7's Avatar
Good luck. The aluminum is cast and it is SHITTY.
I screwed up 2 AN nuts trying to weld them to the fricken cover and I am still looking for someone that can do it.
For the record I am VERY inexperienced with a TIG.
I have some decent MIG skills but I tried that and it just laughed at me.
Old 12-07-2005, 02:51 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Im glad you said that because I was gonna try that with MIG.
Old 12-07-2005, 05:51 PM
SUX2BU's Avatar
i welded mine and they came out perfect. i used TIG.its not that shitty of material.
Old 12-08-2005, 06:55 AM
WKMCD's Avatar
Phil,
Sent you a PM
Old 12-08-2005, 10:45 AM
LOnSLO's Avatar
I've welded AN fittings on them plenty. I always bead blast the covers first, to get rid of any trash or dirt. That makes a huge difference.
Old 12-08-2005, 12:37 PM
93LS1RX7's Avatar
This is what I should have done probably.
Old 12-08-2005, 02:47 PM
MrDude_1's Avatar
i personally havent welded on them, but ive seen a couple of them with fittings welded on, so it is doable....
