LPE CNC LS6 heads/GT2-3 pushrod length
Old 12-12-2005, 03:58 PM
Rob
Rob's Avatar
Default LPE CNC LS6 heads/GT2-3 pushrod length
I'm going to be installing these heads very shortly. Just wondering if anybody has run this setup. What length pushrod should I end up running?
Thanks
Old 12-12-2005, 04:15 PM
conan's Avatar
If the heads aren't milled ----> 7.4".
Old 12-12-2005, 04:29 PM
Rob
Rob's Avatar
Nope, not milled. I figured it would be 7.4" but just wanted to make sure.
Thanks
Old 12-12-2005, 05:11 PM
redtail2426's Avatar
i think with unmilled heads and stock head gaskets its 7.425.Its debatable some run 7.4 and some run 7.425.What you should do is just run a cometic .045 and then use the 7.4's.This will give you a better quench,compression,power,and better preload with the 7.4's.cant go wrong
Old 12-12-2005, 05:40 PM
vettenuts's Avatar
Thanks
Sure hope you plan to post some results
Old 12-12-2005, 08:39 PM
yeah we are gonna need results on this.I have the gt2-3 and will be putting on a pair of ported ls6 heads.I was gonna put a bigger cam in when i did it but if you easliy get over 400 rwhp with that gt2-3 then i will keep it in my car.im looking forward to this one.
Old 12-13-2005, 04:51 AM
Rob
Rob's Avatar
I plan to post the results but I've got people pulling on me to go with a bigger cam at the same time...
Old 12-13-2005, 12:52 PM
George V's Avatar
I am installing the exact same setup this winter. I am hoping for 400 RWHP and some nice torque gains.
Old 12-13-2005, 01:17 PM
ibjamin's Avatar
Hang on there... Are these the GM Performance Parts ones? Which part # did you get? They have 2 different ones, one with 65cc chambers and one with 62cc. The latter ones are shaved .055" and will need shorter push rods.
George E.
Old 12-13-2005, 01:37 PM
Rob
Rob's Avatar
Mine are 65cc
Old 12-13-2005, 02:23 PM
George V's Avatar
I also have the 65 CC. There are 60.9 CC available under PN 88958622
Old 12-31-2005, 04:31 PM
Rob
Rob's Avatar
Just installed these heads today. Went with .045 Cometics and stock 7.4 pushrods. We decided to check pushrod length. The stock 7.4's seem a touch too long. The pattern was to the exhaust side a little. We shortened up the adjustable rod and 7.350 was pretty much dead center.
Just a heads up for anybody interested
Old 12-31-2005, 04:37 PM
where did you get your cometics and what bore size are they.thanks man
Old 12-31-2005, 04:39 PM
Rob
Rob's Avatar
Thunder Racing. 3.905 bore
Old 01-01-2006, 05:02 AM
Fast GTO's Avatar
How are you liking it so far?
Old 01-01-2006, 07:40 AM
Rob
Rob's Avatar
So far so good. I think its actually quieter than before but that may be a perception problem Haven't hammered it yet as I wanted to go through some heat cycles for the springs. Driving around seems to have a touch more throttle response. That's probably due to the bump in compression, ~10.7:1. Other than that, it feels just like it did before the head swap. I'm sure once I start going faster than 3K, I'll feel a difference.
Old 01-01-2006, 09:11 AM
JS
JS's Avatar
I like the setup...You did go with the 65CC...
Its gonna fly,I might be joining u if I can pickup as set of heads for 1K
Old 01-01-2006, 09:37 AM
Rob
Rob's Avatar
Yep, 65cc. Finally stepped into it. Seems to pull a little better once above 3K I'm going for a touch up on the tune this week. Then wait for the tracks to open to see what it does.
So far, driveability hasn't changed. Still drives great with no noise...stealthy stock sounding on both ends of the car.
Old 01-01-2006, 12:06 PM
can we look forward to any dyno results too.I am curious to see if it breaks 400 rwhp.i have a feeling it will but by how much is the ?..
Old 01-01-2006, 12:10 PM
Rob
Rob's Avatar
Going to get a tune and dyno on Friday. Should have it posted by Saturday.
Hoping for 400/400 but don't think it'll get there but we'll see.
Quick Reply: LPE CNC LS6 heads/GT2-3 pushrod length
