921 Valve Spring set issues
Well I got this 921 valve spring kit from a guy on ls1gto who said the kit was new.
Here is the issue with the hardened valve seat...
After I saw this, I decided I better check the springs out a little closer. To my dismay, it appeared that all of the springs had some minor wear on them. Nothing too serious with the springs though...
As a side note, all the retainers appear to be fine
So what should I do:
Replace the valve seat and use the springs after checking them out with a tester tool.
Sell the whole kit and purchase a new kit from a reputable vendor.
Any help would be great!
Originally Posted by vettenuts
It may just be a poor photo, but I don't see the damage to the spring. On the retainer, I would just replace the one although that one would likely work. Also, have you checked spring pressures, are they per specifications?
Those marks on the bottom of the spring locator were not likely from the spring being used. Those should be hardened steel locators, and they sit on top of a soft aluminum head, no way the soft aluminum scratched the locator. The scratches look too irregular to be tooling marks, but i dont know what else it could be from. As long as the side that contact the spring dosnt look like that, im sure youll be okay.
they are not very deep, just a light scratching. I mean, if they were used they would most likely be discolored, etc ... It looks like a machining mark of some sort.
I posted this on another forum, but it almost looks like the seat was installed upside down and the spring was moving around on it. Not very logical, but that's what it looks like happened to it. Otherwise its really hard to explain.
