918's with stock retainers
!LS1 11 Second Club
Originally Posted by 1 Stout Z
Been using 918's with stock retainers and 222/222 .566/.566 112 cam for almost 3 years and not had a problem at all.
!LS1 11 Second Club
Originally Posted by NoGamesLS1
I'm going to run the asa hotcam its 226/236 .525 .525 110lsa with 1.85 rr on the exhaust so it will be a ~.571 lift on the exhaust. So I should be fine right?
!LS1 11 Second Club
Whats the difference between the stock retainers and aftermarket steel retainers? Are they just stronger?
i was planning to use the stock retainers on the swap, but after talking to comp and actually seeing how much slop there is when using the stock retainer with the 918's, i decided to go with the comp steel retainers. much better fit and zero slop.
Originally Posted by nvmy2000ss
Maybe a dumb question but what does the retainers have to do with valve float?
I thought that had to do with springs.
