Any testing done on the vic jr vs gm per?
8 SEC SLOPPY SHOT!!!
I know theres are alot of people kicking around the idea of going to the carb style intake victor jr or gm single plane intake.I don't know of any other ones out there as of now.I know guys with serious setups are looking at this but i would like to know what are the power bands on these intakes?How much more air do these intakes move vs our old 90mm fast intakes.Im hoping somone has track tested or dyno tested with good results.
Popular Hot Rodding built a turbo'd 408 sometime this summer. Buildup was split over 2 or 3 issues, don't have them with me, so I can't quote which issues. It was a turbo application, so it may not be applicable to a NA setup.
They tested with both a modified GMPP manifold (setup with injectors & big throttle body) vs the 90mm FAST. They made more power with the FAST. Don't remember the exact differences, but they were pushing over 1000hp.
I'll see if I can look up the magazine references.
'JustDreamin'
'JustDreamin'
The carb manifolds are compromises around the carburetors nuances. In the old days multiple carbs (Ford even build an inline 4v carb) were ways around that problem. EFI manifolds don't have does issues.
A real EFI manifold should be better. Unless the EFI manifold is so bad even a carb manifold is better.
I'm trying a modified sb2.2 intake (same kind of deal but much much bigger and taller and fully ported) that has been custom modifed by ESP with my c5-r heads. Should be pretty interesting when things finally come together.
'JustDreamin'
'JustDreamin'
'JustDreamin'
This stuff is interesting, however it still reflects the poor selection of aftermarket intakes. Adapting a carb intake because it flows better, importing individual TBs from downunder, and only one intake being mentioned here (the FAST), is really a oiir state of affairs.
For a carb SBC, their are literally dozens of manifolds. Why isn't there the same choice for the LSx?
1.) The SBC has been around since 1955. That's 50 years. Since the LSx series didn't show up until 1997 (that's 9 model years ago), I'd expect that by 2047, there ought to be plenty of choices. Basically, the aftermarket support for the LSx series engines is nowhere near the SBC, but it is getting better every month.
2.) The factory offerings (LS1, LS2, LS6, LS7, truck manifolds) are pretty darned good. Add to that the FAST setup and there is a ready made manifold for "most" setups. Its not until you get fairly radical that the available manifolds come up short, and at that point, in the market's current state of development, you'll need to invest in something tuned for your specific application (like a sheetmetal intake).
Just my opinions.....
'JustDreamin'
LS1Tech Co-Founder
I hear that single plans have better fuel distribution over a sheetmetal intake, but for most folks running a single plan and cutting the cowl is problematic.
I have a Beck sheetmetal intake, and I have been trying to get an Edelbrock intake. I was going to dyno both with my new 2006 turbo setup.
