How reliable are Cometic Gaskets for a Street Application
Old 12-29-2005, 10:47 AM
vettenuts's Avatar
Default How reliable are Cometic Gaskets for a Street Application
I have been reading a lot about Cometics leaking. Are these reliable gaskets on the street?
Old 12-29-2005, 10:56 AM
JoeyGC5's Avatar
about 6-8k miles on mine so far. Been on two 1500 mile roadtrips
Old 12-29-2005, 11:01 AM
Nasty N8's Avatar
If deck serfaces are straight and smooth they should not leak.
Nate
Old 12-29-2005, 11:04 AM
LS1 BU's Avatar
I've reused mine Three times in three years never had a problem.
Old 12-29-2005, 02:28 PM
Beast96Z's Avatar
If there gunna leak, you should notice it right away. Mine leaked, but I believe the deck surface was questionable. My new motor will be getting them.
Old 06-27-2008, 01:02 PM
vettenuts's Avatar
Bringing this back from the dead for more data, plus someone else is asking and was told by a shop that Cometics aren't made for a DD.
Old 06-27-2008, 01:43 PM
99blancoSS's Avatar
Surface prep!! GM has OEM MLS gaskets.
Old 06-27-2008, 01:52 PM
Jon@Texas-Speed's Avatar
Cometics are just fine for a daily driven setup. We sell and install them on DD cars all the time. With the right surface prep (as required for any gasket) is crucial to ensure a good seal. I recommend putting a thin coat of copper gasket spray prior to install to help them seal. I personally have reused my head gaskets on my 408 twice now and they have held up to a 300 shot, no problem!
We carry several bore sizes and gasket thicknesses on the shelf. Let me know if you have any questions, concerns, or need pricing!
Jon
Texas Speed & Perf.
Old 06-27-2008, 01:57 PM
Big Bird WS6's Avatar
Jon
Texas Speed & Perf.
jon on cometic web site the gasket for a ls3. is .052 think. will this be fine on a boosted motor? in the 1000 rwhp range. (18psi, and nitrous to make up difference)
Old 06-27-2008, 02:09 PM
slt200mph's Avatar
I have over 30,000 miles on a set in my DD no problems at all...
Old 06-27-2008, 02:18 PM
99blancoSS's Avatar
Yep, ^^^^
the point I was making is that a Cometic is a MLS . Multi Layer Steel and Gm uses MLS.
Old 06-27-2008, 03:30 PM
HEMIETR's Avatar
No problems here as well. Deck surface is very important.
Old 06-27-2008, 04:17 PM
Viper's Avatar
LS1Tech 20 Year Member
No problems here, 30K DD.
Old 06-27-2008, 06:42 PM
Fratsit's Avatar
No problems here. I have around 3000 miles on mine. I think you'll be fine.
Old 06-27-2008, 07:26 PM
HavATampa's Avatar
No problems here. Over 8k miles and have been reused twice. I also sprayed them with a little copper sealant even though Cometic doesn't recommend it.
