Worthwhile cam upgrade?
Looking to replace my TSP 225 since I added a set of Tea 5.3 stage 1.5 heads. It's not a daily driver. Mods are in sig. 4.10 gears are going in right now. Looking for more power all over. Brent at Tea suggested 230-234 int. dur and 236-240 ex. dur. I will be checking for clearances and will flycut if needed. Here are the specs of a Comp Cam I'm looking at using. Attached it as a text document since the formatting is being thrown off. Good upgrade over what I have or not worth the time?
!LS1 11 Second Club
Can't see the attachment for some reason.
TSP Torquer II, TSP 233/239, Thunder 230/236 all worth a look.
Good luck!
I ran a TSP 231/237 with those heads with good success. Wouldn't recommend it though over the above options. The others offer much more power under the curve.
Good luck!
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I got it to open. Here it is guys:
LIFT DUR. OPEN CLOSE AREA
Lobe I1 ---- ---- ---- ----- ----
Centerline 113.5 ATDC 0.006 282.5 26.4 BTDC 76.1 ABDC 27.93
.050 Lift C/L 114.0 ATDC 0.020 257.8 14.7 BTDC 63.1 ABDC 27.77
Runout 0.00070 0.50 230.8 1.4 BTDC 49.4 ABDC 27.28
Peak Open Acc. 0.000433 0.100 201.6 13.0 ATDC 34.6 ABDC 26.16
Peak Nose Acc. -0.000305 0.150 176.6 25.4 ATDC 22.0 ABDC 24.55
Peak Close Acc. 0.000394 0.200 151.0 38.2 ATDC 9.2 ABDC 22.25
Lift @ TDC 0.0542 0.250 121.8 52.7 ATDC 5.5 BBDC 18.91
Minimum Flat 0.300 84.5 71.4 ATDC 24.0 BBDC 14.01
Follower Dia. 0.9339 0.34686 ----- PEAK LIFT ------- 0.589 w/ 1.7 rockers
Lobe E1 ---- ---- ---- ----- ----
Centerline 113.5 BTDC 0.006 287.7 76.5 BBDC 31.3 ATDC 28.93
.050 Lift C/L 113.7 BTDC 0.020 263.0 64.9 BBDC 18.1 ATDC 28.76
Runout 0.00110 0.50 236.1 51.8 BBDC 4.3 ATDC 28.27
Peak Open Acc. 0.000423 0.100 206.7 37.2 BBDC 10.5 BTDC 27.24
Peak Nose Acc. -0.000276 0.150 181.6 24.7 BBDC 23.1 BTDC 25.67
Peak Close Acc. 0.000423 0.200 155.8 11.8 BBDC 36.0 BTDC 23.21
Lift @ TDC 0.0629 0.250 126.8 2.8 ABDC 50.5 BTDC 20.13
Minimum Flat 0.300 90.0 21.2 ABDC 68.8 BTDC 15.05
Follower Dia. 0.9271 0.350 17.3 58.0 ABDC 104.7 BTDC 3.04
0.35173 ----- PEAK LIFT ------- 0.597 w/ 1.7 rockers
Good luck!
Good luck!
Heh...thanks orangeapeel, awesome name by the way. That's why I didn't post it in the thread, it's all scrambled and the columns don't line up. Basically, it's 230/236 .589/.597 on 114 +4. Went with the 114 to get a little smoother idle. I was looking for something close to the cam Sidestep uses (Mamanator 2.0 ) as suggested by Tony. I called Tony and told him what I was looking for and he basically gave me the same info as Brent. No real numbers on lift though.
Originally Posted by PREDATOR-Z
I can vouch for the TSP Torquer V2
232/234, .595/.598 112/113/114 LSAs
I would like to buy a wet kit eventually. Installed a Racetronix fuel pump this past weekend for future needs. Will be installing 30lb SVO injectors in about a month.
Originally Posted by LS1 BU
Are you gonna spray?? If not then use something around a A F13. I use a Comp 230/232 with a 150 shot and have great results.
LS1Tech Premium Sponsor
The Torquer V2 232/234 .595/.598 should clear with that setup. We've run it with our PRC cylinder heads with no issues so I bet you would be fine. They are still on specials for $359.99 on our site!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
