Ls6 Camshaft Specs
Old 01-06-2006, 01:38 PM
Torque_Wrench's Avatar
Default Ls6 Camshaft Specs
Can Anyone Tell Me The Specs On A Ls6 Camshaft? Like Duration, Lift And So Forth?
Old 01-06-2006, 02:26 PM
SSilverSSurfer's Avatar
the 01' Z06 cam is 204/211 .515/.522 116lsa
02' Z06 is 204/218 .551/.547 117lsa
Old 01-06-2006, 02:51 PM
THANK YOU SIR....GREAT INFO......
Old 01-06-2006, 03:12 PM
no problem
Old 01-07-2006, 02:08 AM
jfrc2000's Avatar
i have seen many different specs, depending on source
early versions- 204/211 525/525
later versions- 204/218 551/547 or 204/217 551/555
i have even seen later specs as high of lift as 561
Old 01-07-2006, 07:21 AM
Chris81's Avatar
I've always seen.. (02+ cam)
204/218
.551/.554
117.5 LSA
Old 01-07-2006, 01:02 PM
LS1 Tech Administrator
Patrick G's Avatar
Exact specs:
02+ Z06 camshaft 0.006 0.050 0.200
Intake Duration - ID 270 204 125 02 LS6 intake
Exhaust Duration - ED 277 218 135 02 LS6 exhaust
Lobe Center Angle - LSA 117.5 117.5 117.5
Intake Centerline - ICL 120 120 120
Intake Valve opens - IVO 15 -18 -57.5 BTDC
Intake Valve closes - IVC 75 42 2.5 ABDC
Exhaust Valve Opens - EVO 73.5 44 2.5 BBDC
Exhaust Valve Closes - EVC 23.5 -6 -47.5 ATDC
Exhaust Centerline - ECL 115 115 115
Overlap 38.5 -24 -105 degrees
Notice that the cam is retarded -2.5 degrees. The ICL is actually 120. This is one of the big reasons why the '02+ LS6 cam will rev so well with such small intake duration. An intake valve closing point of 42 degrees works very well.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 01-07-2006, 09:04 PM
jrp
SN95 Director
jrp's Avatar
Originally Posted by Patrick G
Exact specs:
all the genIII/IV cams are retarded from the cam doctors i've seen.
Old 08-21-2017, 02:13 PM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
http://shop.brutespeed.com/Comp-2002...A-Comp-LS6.htm
Here's Comp's version. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 08-25-2017, 10:47 PM
stockA4's Avatar
Originally Posted by Bob@BruteSpeed
I'm pretty sure the shelf 212/218 .558/.563 115+0 lsa is the improved comp version of the LS6 cam. It's the exact one I chose for my stealthy turbo LR4 swap.
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=1089&sb=2
looking at the OEM LS6 cam specs, geeze those lobes are lazy! The advertised intake duration at .006 is 270 degrees for only 204 degrees @ 0.050! The old high lift comp (which is also considered pretty lazy by today's standards) actually has less duration at .006 (265 degrees) but more at .050 (212). It also closes the intake valve quite a bit sooner (68 vs 75) so it should have a noticeably better low end and mid range when used in the smaller 4.8/5.3 engines in heavier vehicles which is often a complaint of those who have run the original style LS6 cam and are disappointed with the noticeable loss of low end power.
Old 08-25-2017, 10:53 PM
stockA4's Avatar
Looks like my link didn't work.
just google search 54-424-11 to see the cam card.
the 204/218 117.5 lsa cam is a waste of time in most cases Imo
Old 06-17-2023, 10:55 PM
Shtstr's Avatar
Sorry for digging up an old thread.
Does anyone know what the actual cam valve events are for the ls6 cam.
as in.
Inlet open before tdc
Inlet close abdc
Exhaust opens atdc
Exhaust closes atdc
Thanks in advance everyone as I'm trying to work out what the factory dynamic compression ratio was set at.
Old 06-17-2023, 11:41 PM
Received 3,024 Likes on 2,355 Posts
Check Post #7 above. Pat Guerra knows his stuff. If he posted those specs, you can believe them.
The following users liked this post:
grubinski (06-20-2023)
Old 06-17-2023, 11:43 PM
gametech's Avatar
as in.
Inlet close abdc
Exhaust opens atdc
Exhaust closes atdc
If you read anything you would see that exact info is already in this thread, and has been since 2006.
G Atsma (06-17-2023)
Old 06-18-2023, 05:43 PM
grinder11's Avatar
I understand you're looking for stock specs. This is only my opinion, but if you're putting an LS6 together, as long as you've got it on the stand, I'd at least go with the upgrade cam. Not talking about a 230/240 duration@.050", with .640" lift! But a simple 215°/220°, .590"-.600" lift would make a tremendous difference with OEM 243 heads, and would idle and drive about as close to stock as you're likely to find. Again, my opinion. But if I had an LS6 going together, it sure as Hell wouldn't be with a 204° intake duration, .550" lift cam.....
Old 06-18-2023, 05:55 PM
grinder11's Avatar
BTW, I have read that the '01 LS6 cam had
207°/211° duration, .525"/.525" lift, 116 LSA. A lot of figures out there. HOWEVER, I once actually witnessed 2 Z06s run each other at the strip many years ago. They were stock, and identical, except one was an '01, and the other was an '02. Looked like twins! The '01 had 1.8 rockers, rather than stock 1.7s. Only mod either car had. I don't remember which car won. I only paid attention to mph, which is most indicative of power output. The '01 had around a 1mph higher trap speed, without exception. This somewhat verified what I'd heard up to that point, and that was if you ran 1.8s in the '01s, they ran as good as, or better than, the '02-'04. FWIW......
Old 06-18-2023, 05:56 PM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
My Cam Motion Titan 2 in my ls6 has been awesome. Great street driving and has been shifted over 7k.
Old 06-18-2023, 07:35 PM
According to the Summit database the 01 LS6 cam specs are- 204/211, .525/.525, 116 LSA
After that (02 on up) it went to- 204/218, .555/.551, 117.5 LSA
Old 06-18-2023, 08:19 PM
Shtstr's Avatar
I'm building a ls6 with high compression 11.67 to 1 with a suitable cam for the dynamic compression ratio.
I want to find out the factory cam valve events so I can calculate the factory dynamic compression ratio and know what to aim for.
Because too small of cam will give to much dynamic compression ratio and to big of cam will lose torque down low.
Old 06-18-2023, 08:21 PM
Shtstr's Avatar
I have those specs but it doesn't give you actual timing events only @50.
Can be a big difference between the two depending on the ramp rate.
It could be anything.
Quick Reply: Ls6 Camshaft Specs
