cam
Old 01-08-2006, 09:38 PM
nexvctm2001ss's Avatar
Default cam
What would be a good cam 2 get about 450+rwhp with stage 2 ls6 heads, 78mmTB,LT's,ORY,ect.?
Old 01-08-2006, 09:40 PM
SSilverSSurfer's Avatar
S cam form HPE...i have it and its great....
Old 01-08-2006, 09:47 PM
Default cam
Which one do you have? don't really know about cams
Old 01-08-2006, 09:50 PM
DocEwww's Avatar
How lopey is that cam?
Old 01-08-2006, 09:52 PM
ReD_Z28's Avatar
ms3,g5x3 but u need to fly cut the pistons.
Old 01-08-2006, 09:55 PM
Default cam help
How big can u go b4 u have 2 fly cuy?
Old 01-08-2006, 09:57 PM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
Not on stock heads you don't.
With Stage 2 LS6 heads, an F14 from Futral is up to the task. So is the MS3 from Texas Speed.
Call Futral or TSP or Thunder and ask them what cam they recommend for your heads.
Specify any milling, cc, and valve size that's been worked on your heads.
Good luck!
Old 01-08-2006, 09:59 PM
Default cam
2.05-1.60 59cc?
Old 01-08-2006, 10:00 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Good luck!
Old 01-08-2006, 10:01 PM
raps pretty frickin hard...and flycutting was not required seeing as that the S cam is bigger than the MS3
Old 01-08-2006, 10:04 PM
ReD_Z28's Avatar
These are proven recipes, the both made 450 hp easily with heads milled to 11:1CR, The fly cutting is not that big issue and cheep way to run big cam and high CR ratio.
Old 01-08-2006, 10:07 PM
Default cam
How much is it 2 fly cuy pistons?
Old 01-08-2006, 10:13 PM
!LS1 11 Second Club
Flycutting is avoidable and it is a pain in the ***. IMO.
Seriously, this is going to be a big cam naming thread and you're not going to come away with anything learned.
If you want to learn something, read JRP's sticky at the top of this forum, and call a few shops.
Heck, with a FAST 90/90 and a good exhaust, 450rwhp is attainable with medium sized cams.
Old 01-08-2006, 10:18 PM
sparky t/a's Avatar
i hear the new VTEC cams are pretty stout.
Old 01-08-2006, 10:31 PM
Zzzzzzzz
