g5x4 cam...what can i do for heads??
Old 01-30-2006, 10:24 PM
gsxzo6's Avatar
Default g5x4 cam...what can i do for heads??
sorry this is my second post...i kinda need this answered quick...i emailed lg motorsports no response yet...anyways i have a 02 z06 with these mods
kooks 1-7/8 headers full 3inch
lgm g5x4 cam specs?
90/90 fast set up with ls2 throttle body
full intake
ported ls6 oil pump
water pump(mezier electric)
60 lb injectors
STOCK BLOCK (i may put a girdle on this) and eventually ls2 402 but right now its a 346
THESE PARTS ARE NOT INSTALLED YET KEEP THAT IN MIND
what heads can i do with this st up...i want high compression and to rev to 7100...what heads? these are what i was thinking but there milled to 58cc
Specs: (Assymbled) ls1 castings Stage 3
Milled .50
58cc combustion chambers
Heat coated Rev valves
Heat coated chambers
Comp beehive springs good to .650 lift
Tituanim retainers
intake runners 215cc
exhaust runners 70cc
intake vavle size 2.02, exhaust 1.57
5 angle valve job
Intake flow numbers
.100 80
.200 148
.300 205
.400 257
.500 282
.550 293
.600 303
????? yes...no...will it work????? will the piston to valve clearences be existent?
OR
225cc heads of some caliber? and if this what cc chamber...or is there something im missing...sorry this is a newb question i want to make this work...this is a weekend car only and not driven much i also want massive upper rpm rush all the way to 7100....PLEASE HELP I WANT TO GET THIS DONE ASAP
thanks in advance
justin
Old 01-30-2006, 10:31 PM
LS1 Tech Administrator
Patrick G's Avatar
Those heads will work, but you'd probably go faster with some small bore AFR 225 heads. I just got mine last week and plan on bolting them up this week. I'll find out soon if they're worth swapping for the AFR 205s.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 01-30-2006, 10:39 PM
gsxzo6's Avatar
hey thanks for the fast response is it true this cam can be installed with flycutting?
also if you have the specs can you pm me them? lg is no help and i own the damn thing...i bought this cam used with low mileage...also will i have to flycutt with these heads? what do you recommend in a 241,243,ect casting thats ported out? or should i just bite the bullet for 225cc or better heads(etp)? sprry for alll the questions i just sold a vehicle and have some cash to play with....what do you think of the dart 225cc ? like these...
http://forums.corvetteforum.com/show...rt&forum_id=53
Old 01-30-2006, 10:51 PM
DocEwww's Avatar
I'd put Katech rod bolts on ur list if ur reving that high.
Is there a budget for these heads?
Old 01-30-2006, 10:53 PM
DocEwww's Avatar
"Valves:
They come with brand new 1 piece stainless Ferrea 2.02" or 2.05" Intake valves and 1.60" Ferrea exhaust valves."
Larger than stock vavles = flycut with that big of a cam
gsxzo6's Avatar
kind of a budget...this is just what i found and would give me decent comp ratio and they flow over 300 at .600 lift....what do you have in mind
Patrick G's Avatar
BTW, the ballpark for the G5X4 cam specs are around 236/244-111+1 or 2. Around the size of a TSP MS3 but with a narrower LSA. It's a nasty cam, but a good one.
Old 01-30-2006, 10:56 PM
DocEwww's Avatar
https://ls1tech.com/forums/showthrea...&highlight=prc
Those or the patriots I'm looking at with my big cam setup. I don't want to flycut.
I'm also interested in the new small bore AFR 225s, after talking to Matt at TTP, theyre not sure if theyre gonna have to flycut with cams of this size. Im thinking they will.
Old 01-30-2006, 10:57 PM
gsxzo6's Avatar
i knew the basic specs and i know the lift is around .612 on the high side...do you guys think with those heads and this cam along with my mods ill be around 480+ wheel?
Old 01-30-2006, 11:00 PM
gsxzo6's Avatar
if io have to flycut thats no biggie...but will the heads and cam support the 7100 redline? or should i just go to TEA and have them do my heads up(243 z06)?
Old 01-30-2006, 11:03 PM
DocEwww's Avatar
If you dont mind flycutting and price isnt an issue go with proven AFR 225s or the new 11* ETP heads (which are back ordered)
Old 01-30-2006, 11:07 PM
gsxzo6's Avatar
with 225cc afr's dont they only come in a large cc chamber? or did somehting new come out ? how much would i mill them to get about 11-1 compression? thanks for the quick replys guys keep them comming
Old 01-30-2006, 11:09 PM
gsxzo6's Avatar
what about the patriot heads? ls6 stage 3's on a stock 3.9 bore?
http://sites.reachtheworld.tv/waterN...05234&DID=1225
what gaskets would i need to do this ?
Old 01-31-2006, 12:04 AM
moeZ28's Avatar
if you mill the stock heads, or buy stock heads that are milled .050, you are gonna definitely have to flycut with a G5X4 cam. and more than likely you will have to go with 7.350 pushrods. the X4 cam clears stock, unmilled heads, but milling them and using aftermarket valves can create problems. make sure you check your piston to valve clearance before bolting everything up or you could have a major problem.
Old 01-31-2006, 12:15 AM
DocEwww's Avatar
The S3 heads are recommended for larger than stock displacement
Old 01-31-2006, 08:32 PM
gsxzo6's Avatar
hmm all right thanks for all the info...can i do rod bolts through the oil pan with the motor still in the car?(just take the pan off) also i think i may just go with cheaper all turnative...which is the patriot stage 2's with the smaller combustion chamber(i think 58cc or 59cc)....also THIS IS A BIG QUESTION...
what size pushrods would i need for the g5x4 on the patriot stage 2's with the smaller combustion chamber? i know stock unmilled id go with 7.4 of some kind.
thanks a lot
Old 01-31-2006, 11:01 PM
gsxzo6's Avatar
pleaseeeeee
Old 02-01-2006, 12:44 AM
DocEwww's Avatar
For F Bodies u can just drop the K member...dunno much about the vettes.
