What makes the LS1 more powerful then the LT1?
I know that the Lt1's used reverse flow cooling and the ls1's used a modified form of that (or so I think), and the ls1's have 6 bolt mains. But in all actuallity what accounts for the big hp increase at the rear wheels? They have the same pistons/engine sizes(w/ the lt1 being an actualy 350). Is it because the ls1 intakes/heads are just that much better?
What are the main differences. I am curious about the piston rings, do the ls1's use something different?
The LT1 is a 350 and the LS1 is a 346. The LS1 is aluminum and quite a bit lighter. The block isn't where the power is at. The LS1 has a bigger cam and MUCH better heads and intake. The PCM and coil on plug ignition system is also WAY better. I could go on and on abouit the differences, because they are NOTHING alike. About the only thing they have in common is the fact that they are both V8's and made by GM.
Originally Posted by Supernoma
LT1 is an iron engine block, LS1 is aluminum engine block. The LS1 was pretty much a total redesign of the small block engine.
It's all in the intake runner flow, combustion chamber design, and intake manifold. It's all about airflow. The bottom end (design) is similar to LT1 or small blocks. The heads are the main difference. Lightweight valves and EFI injection help.
Originally Posted by KRS30
they share a main bearing size i believe...i think that's about the only similarity though.
Originally Posted by 1QuickT-A
I would have to say the biggest reason is this..
The LS1 has 15* heads compared to 23* LT1 heads...
More flow capabilities=more power
You can build LT1s to make more power, but let us just say that LT1 limits are way below what a max effort LS1/LS6 can make.
