TSP magic stick VS. T-Rex
ok heres the Deal...im gonna cam my LS1 befor racing season rolls around and im stuck between these two cams. so i need your guys help...
my goal is low 6's in the 1/8th mile N/A...my mods as of now include:SLP lid, Loudmouth, 3.73 gears, pacesetter Longtubes, SLP 85 MM MAF (LS6 intake shorty after cam install) and i know ill need a big stall for both cams but im wating till i decide which cam befor i decide the stall size...
i put 200 miles on my car at the most a week so its not a daily driven car by any means so i can handle sucky *** drivabilty. Also the guy that tunes for my performance guy is really hard to get into touch with but he is a master at the craft of tuning LS1's, so ill be driving on a tune from a Vinci/crane power tuner(that can tune bigger cams)...
which way would u guys go?
Low 6's in the 1/8th...? that's like mid 9's. If you want to do that you need a purpose built car with a lot of weight reduction. Judging by your lack of listed mods I'm going to say with either setup you'd do well to run a 7 flat. T-rex and a 4400 stall would be a solid start. Not trying to be a dick - but you have to crawl before you....
can run 9's
can run 9's
TRex with 3.73's and auto? I like my magicstick but then again I drive an M6 as a daily driver..... Trex too big for an auto in my opinion. MS3 and spray the biatch!!!!
t-rex with 4400 stall and supporting bolt-ons should get you near/under 7.5
weight reduction might be needed to achieve "low" 7s 1/8 mile...
magic stick is a good street cam and is nothing like the t-rex. the t-rex is much larger than the ms3 and will net better ETs....not because it has A LOT more power, as the peak numbers aren't far from each other, but rather HOW it makes the power and HOW LONG it makes power. a properly tuned t-rex car should peak about 6,400 and pull to ~7k, if not a little bit more. seems the ms3 cars peak ~6,700 and fall off hard at 6,800.
i, too, had this decision...and said f yall i'm doin a custom grind
lg motorsports makes any of the g5x cams. opt for a g5x4 if you want that much power. it falls in between the ms3 and t-rex, on the conservative side.
good post man...im gonna do some more research but ill prolly end up with one of these two cams...but imn gonna check out lg motorsports first
I'm running low 7's, but I have some older AS S2 heads. I was running an SS4000 stall and 3.23 gears, full weight car and almost 120 MPH in the 1/4. So yeah, with a big stall and I would look at 4.56 gears, low 7's is very possible. My trex peaked at 6800 and pulls hard to 7200 RPM, but I have a forged bottem end to handle the high RPM.
I vote for the MS3. Its a great cam and I ran some 7.4s on motor and 6.6 on gas with it and a tight 3500 converter. I have recently installed a 4400 but no times yet.
ok what about the crane cam
228° 232° .600" .600" 112°
its got a big lift but not a huge duration but still looks like it'd make some big power and its for sure tunable with my crane cam tuner
dear s 346k. I dont know what you are failing to notice, but my cars weight with me out of it is in sig. I am not driving a gutted out shoebox and the only thing that my car is missing is a rear seat and bumpers. And if you think that a built 35o turbo is better than a built 4L60, then you need to check into the gearings of those trannys. A 4L60 has a lot lower first gear than a 350 and that my friend equals a better 60 foot which equals beter et . Except in your case where a 1.70 60 produces 8.18. My friend has a car that puls 1.90 60s and has ran 8.19. And you can take sea level and stick it up your jealous ***. If you think thats why you arent going as fast as you should then my sugestion would be move. Come to where I am from and you can experience my, as you put it guted out, sealevel shoebox. FIRST HAND And yes the converted made it feel stronger out of the hole.
