gaskets n stuff
gaskets n stuff
i was just wondering when doing a heads/cam package what gasket kit to use. im not looking for the latest, high-tech, titanium-polymer, **** just a good all ecompassing kit. hopefully someone can provide me some part numbers. also can someone tell me what belts i need to use my underdrive pulley. i have the slp but i cant imagine the asp would be different. right? they list some part numbers on their site but i wanted to buy from summit as i have a gift certificate and all they carry is goodyear. can anyone help me? sorry for the long post, thanks in advance
If you don't have egr and air, this is what you should need *(with minor upgrades for convience).
-GM LS1 Front Cover Gasket
-GM LS1 Exhaust Manifold Gasket (2 required)
-GM LS1 Oil Pump to Pick-Up O-Ring (if changing oil pump, which you should do)
-GM LS1 Front Main Seal
-GM Multi-Layer Steel LS1/LS6 Cylinder Head Gasket (99+year body)
otherwise GM LS1 Cylinder Head gasket, graphite (both pass. and driver)
-GM LS1 Intake Manifold Gasket Set
-GM LS1 Valve Cover Gasket, 1999 and up (2 required) (also different if 98)
-GM LS1 Water Pump Gasket, 1999 and up (2 required) (get these even if you have a 98)
-ARP head studs
-GM Balancer Bolt (not reusable) or ARP (reusable)
That's all that I can think of.
All can be had from most of the sponsors.
http://thunderracing.com/catalog/?ac...vid=3&pcid=157
To make it easy get this part number on thunder racing's website:
111-12-LS
-ARP head studs
111-12-LS
