Lock washers OK on cam bolts?
My cam bolts loosened on my old setup and now that I have spent a lot of money on a 408, I want to make sure that the cam bolts stay put this time!
I purchased the ARP cam bolt kit which only consists of three bolts . Anything I can do in addition to using ARP bolts to make sure they dont come loose? lock-washers? Loc-tite on ARP bolts?
Also, what torque should be used on ARP cam bolts?
THanks ALL
THanks ALL
Originally Posted by 99whitews6
What type of loc-tite? I used the permaxxx (something) red loc-tite on my old 346 and the bolts came loose . I just dont want to have it happen again.
Originally Posted by skipperbisket
that's weird that you guys have had bolts back out like that, i've done probably 20 cam swaps and never had any issue like that. how did you find out they had backed out?
Originally Posted by GuitsBoy
I patched her up with the red loctite stick (looks like a gluestick or big chapstick).
You wouldnt happen to have a part number or LINK to this would you?
I have access to some military grade loc-tite at work. I might try some of that if I can not find anything else.
Im not sure if its number 268 I used, but it was the high strength red loctite sitck.
I don't know if there's a specified shelf life on thread lockers but when I start a new project and my thread locker or silicone sealer etc. is more than a year old I buy new just to be safe (and properly dispose of the old).
Also if I'm not mistaken there is a product referred to as a "primer" for thread lockers, this may be were that should be used.
