6.0 irong black weight compared to ls1 346?
Old 02-13-2006, 07:48 PM
themack56's Avatar
Exclamation 6.0 irong black weight compared to ls1 346?
how much heavier is the 6.0 iron block than the ls1 346?
Old 02-13-2006, 07:55 PM
strokedls1's Avatar
It is about 105 lbs. heavier than an ls1 alluminum block.
Old 02-13-2006, 07:59 PM
themack56's Avatar
Exclamation
is worth getting a heavy 427 iron block?
Old 02-13-2006, 08:16 PM
strokedls1's Avatar
I would try to get one of those new 6.2L blocks that are 4.065" bore and do an alluminum 415 ci with a 4" stroke. I have an iron 422ci and like it, but why go iron if you don't have to.
Old 02-13-2006, 08:50 PM
KCS
Moderator
KCS's Avatar
Where do yall get these bogus numbers?!
According to Will Handzel, author of How to Build High Perfromance Chevy LS1/LS6 V8s, the aluminum block weighs 107 lbs and the iron block weighs 65 lbs more.
Old 02-13-2006, 08:57 PM
Andy1's Avatar
I think I read 63lbs. was the weight difference in some GM literature. Either way, it's not very much more.
Andy1
Old 02-13-2006, 09:17 PM
383LQ4SS's Avatar
Im pretty sure I have seen several people weight them for shipping and the general concensus was right around 100 lbs AFAIK.
Old 02-13-2006, 09:40 PM
strokedls1's Avatar
Well I guess I get these bogus numbers from weighing the blocks since I have built a few iron and alluminum ls motors. I don't rely on some book to get information. I do have an iron motor in my car right now.
Old 02-13-2006, 09:49 PM
themack56's Avatar
Exclamation
true, about why get iron when you dont have to! on you 422 ci what power do you get out of it?
Old 02-13-2006, 09:56 PM
themack56's Avatar
Exclamation
well i still have to think on how much power i want to produce, irons are better for max hp, so maybe ill swing that way
Old 02-13-2006, 09:59 PM
MountainMotor's Avatar
I'd get an aluminum block if your going to stay NA or w/ a little boost or shot of nitrous. Most guys go with iron blocks because they tend to be stronger so they use them on high boost setups or a big shot of nitrous. They hold the power better than an aluminum block but they do weigh more so it's just according to what your looking to build.
Old 02-14-2006, 12:40 AM
strokedls1's Avatar
I am making a little under 500. I have sprayed it over 600 rwhp though. I may do a turbo soon. I bought the iron back in 02 when iron 6.0 or 5.7 ls1 resleeves where the only ways to get bigger cubes. I went iron to avoid coolant leaking issues and don't regret it. I just think that with the new release of some gm blocks and aftermarket that there are better options. I would rather opt for less weight if it suits the application requirements. Let me know if you need a block because my friend down in costa mesa can get you anything just about stock block wise.
Old 02-14-2006, 10:13 AM
KCS
Moderator
KCS's Avatar
I just figured a GM engineer would know, if I get a chance I'll weigh the iron block I have sitting in my garage.
Old 02-14-2006, 11:18 AM
adillhoff's Avatar
You would get an iron block because the LS1 is one of the worst engines ever made by GM. The oil pump is very weak and the aluminum is too weak for high power situations. As the engine heats up the aluminum will warp a lot more than an iron block. Not saying that the LS1 is futile, I like it a lot. I'm just saying an iron block is superior for durability. The extra 100 lbs. isn't much at all.
Old 02-14-2006, 11:51 AM
DanZ28's Avatar
Worst engine GM ever made??
Old 02-14-2006, 01:40 PM
Your opening a can of worms with about everyone on here.
Old 02-14-2006, 02:39 PM
GuitsBoy's Avatar
Please reference one verified account of someone splitting an lsx block. Just gimme one. It just dosnt happen, man. The heads will lift way before you split a block!
Old 02-14-2006, 03:20 PM
Steel Chicken's Avatar
Oil pump issue was fixed like 4 years ago. High power? Such as what? People run lots of power in the stock blocks and cranks. Pistons and rods (the weak points) are usually good to 600crank HP. Sure, the irons are more durable, but unless you are nearing mega power levels, the LS1 is fine.
Worst engine ever made by GM, thats some funny ****.
Old 02-14-2006, 03:32 PM
98Z28MASS's Avatar
Old 02-14-2006, 10:43 PM
M6HuggerSS's Avatar
that guy is totally right! the 118hp 2.2L in my 98 s10 is WWWAAAYYYYY
better than by OLD CRAPPY 400rwhp LS1.
id take that noisey, gutless, piece of **** any day!
im actually thinking of doing a swap.... and ditching that P>O>S LS1 and throwing in my bad *** 2.2L!
i cant wait.
