Are Stock push rods OK????
Old 02-17-2006, 01:17 PM
mustang93's Avatar
Default Are Stock push rods OK????
Are stock Push rods OK for a TR 224 112 LSA cam???
Old 02-17-2006, 01:25 PM
FstBlkz28's Avatar
You can run them and get away with it ... but most people will say upgrade to hardened b/c the stock ones can flex, which puts slack in the valve train meaning that the lobes on the cam aren't being translated to the valves accurately which can cause u to lose power.
Old 02-17-2006, 01:32 PM
vettenuts's Avatar
Pushrods are succeptible to two things, the end loading and stiffness.
With your cam, you now have faster ramps and likely stiffer springs. Therefore, you have higher end loads on the pushrod due to spring loads and acceleration levels. As the pushrod flexes, under these higher loads, it needs more strength to resist buckling and failing. So in a word, No. I think you are playing with fire. I wouldn't rev it much if it were my car, the risk to damage is just too high.
Old 02-17-2006, 01:43 PM
mustang93's Avatar
Ok so what lingth push rod will I need to order.. I am going to order hardened push rods... THANKS!
Old 02-17-2006, 01:47 PM
02 Camaro SS's Avatar
I wouldn't run a cammed engine with stock pushrods. It's not uncommon for people to bend the stockers with the stock cam. I believe the pushrods are 7.400"
Old 02-17-2006, 01:55 PM
vettenuts's Avatar
Call TR, they should be able to hook you up with the correct pushrods for their cam.
Good luck.
Old 02-17-2006, 01:59 PM
mustang93's Avatar
Thanks Guys... The reason I asked is.. Wile driving down the road in like third gear or so I noticed some noise like the rockers were loose?? But there not it dont make the noise wile ideling... Plus I took the valve covers back off and checked...
Old 02-17-2006, 02:43 PM
TopFlite's Avatar
Stock pushrods are just barely strong enough for a stock LS1. Put in some chrome-moly sticks! 7.400 is the stock length for the pushrod.
Quick Reply: Are Stock push rods OK????
