Oil pressure.. Am i S-O-L???
Old 02-21-2006, 07:17 AM
LostCauseZ06's Avatar
Default Oil pressure.. Am i S-O-L???
alright.. we got my 408 back together and ever since it has been back together i noticed my oil pressure is always pegged.... its 130 (maxed) in my DIC gauges and its pegged on the needle....
when i put the key in the car it jumps up to about 75.. and then climbs up to 130 almost instantly.. this is BEFORE i even start the car....
faulty sensor???
the engine is a HPE 408, stage 3 heads, big cam..
we DID put in a ported LS6 high flow oil pump in it... but the oil pressure jumped up to 130 even before we started the engine for the first time.. its just like its pegged all the time so im thinking it has got to be a sensor????
Old 02-21-2006, 07:19 AM
btw.. the car runs AMAZING... oil temp is perfect.. car temp is perfect... does leak some oil but we think its out of the dipstick from not replacing the o-ring on it... anybody have any ideas??
Old 02-21-2006, 07:27 AM
radkon's Avatar
So you are saying that oil pressure is at 130 before you start the car? Unless you have an electric oil pump you shouldn't have much if any pressure before you start it. I'd say faulty sensor or wiring.
Old 02-21-2006, 08:25 AM
thats exactly what i was thinking.. gotta be a bad sending unit... will the oil pressure stay in the car 24/7???
after i shut off the car and let it sit overnight when i put the key in the next morning the oil pressure does my full sweep (z06 full gauge sweep) then it settles at 60 PSI for a sec.. then climbs rapidly till its pegged.... this is BEFORE i start the car... i thought that the oil pressure went away after you shut it off???
Old 02-21-2006, 08:56 AM
felton316's Avatar
Not sure on the vettes, but on the F-body, if the sensor is cracked or broken, it will read 0. If the sensor is left unplugged, it will peg out to the max.
Old 02-21-2006, 09:00 AM
hrmm.. maybe it wiggled loose or maybe there is a cut in the wire... i will have to check it out..
Old 02-21-2006, 10:07 AM
RAACCR's Avatar
Replace the oil pressure sensor behind your intake manifold...very common problem on 'Vettes.
Old 02-21-2006, 10:58 AM
im starting to come to the realization that there are lots of "common problems" on corvettes...
