Katech Rod Bolt Swap - Engine Removal?
I've got a set of Katech rod bolts here and I want to install them before spraying the motor in the next month or so. I do have access to a lift, and I'm hoping I can do the swap with the engine in the car. I do still have the stock K-member.
How did you go about installing your rod bolts?
Thanks in advance guys!
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I am not sure if it is listed on www.installuniversity.com or not, but I know that you can take out the K-Member and pull the pan without pulling the engine when you replace them.
I didn't see any information at Install University. Hopefully some guys will have first hand accounts of the process... TNT 150 or 200, wet...
Originally Posted by orangeapeel
BTW: how much do you plan on spraying and what method? Direct or Wet?
hmmm, I know I have seen a write-up around here somewhere in the last few months. I bet really all you need is tq specs.
you can do it with the engine in the car if that was your ultimate question about it.
