Who makes Who's cams???
I have always wondered where do the LS1tech sponsors get their cams ground at.
The cam manufactures that I know of are:
- Comp Cams
- Crane Cams
- Isky
- Cam Motion
Also, who makes the stock cams for the GM LSx engines?
- Comp Cams
- Crane Cams
- Isky
- Cam Motion
Off the top of my head
Vinci uses crane
Futral Motorsports uses cam motion
Speed INC uses comp
I'd say most shops use comp cams. Those are the only ones I can think of, that are the big shops. There are other big shops such as thunder but I don't know what they use. Most likely comp.
Vinci uses crane
Speed INC uses comp
Originally Posted by Billiumss
Anymore?
One of the major "rock" suppliers I know pretty good. In a conversation I had with him a couple of years ago they had over 1200 accounts that bought grinding rocks specific for cams. It's a long list and the big fish have not even been named.
Originally Posted by vettenuts
At one point, I thought they were all using Crane blanks as Crane was the only one capable of the hardening process. Comp has since developed their own process. Not sure on the other companies, but I believe David Vizard discusses this in one of his books.
Retired Street Racer
Originally Posted by Texas Speed's Website
The Magic Stick V3 camshaft is Texas Speed's premier LS1 camshaft! This camshaft has gone as fast as 10.50s n/a with stock heads in our 98 Z28 test car.
This camshaft features Comp Cams XER lobes! The XER lobes have been proven to make big horsepower & torque thanks to their aggressive ramp rates & healthy lift.
2300-6800 RPM Power Band with a peak around 6400rpm; This is an excellent performance camshaft with a rough idle!
Originally Posted by Kraest
I'm 99% positive Thunder also uses Cam Motion.
Most of the southern shops use Cam Motion, since they are located in Baton Rouge.
Mike
Mike
Definitely incorrect They use another company
