Two piece timing cover ?
Old 03-03-2006, 10:19 PM
RPO_Z06's Avatar
Default Two piece timing cover ?
What is the best bang for the buck ?
Anyone know what ever happend to the guy that had his friend make one on a cad machine ? If I had the cad file I could make one, or several..
I wish search still worked like it did before.
Old 03-03-2006, 10:40 PM
Hugger's Avatar
Nasty Performance and QTP both make two piece timing covers. Nasty is cheaper. They are both sponsors to the right---->
Old 03-03-2006, 11:49 PM
santiago's Avatar
I was tryin to search this also
Old 03-04-2006, 02:58 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I wouldnt advise cutting your stocker in half either.
Old 03-04-2006, 09:10 AM
Order 66's Avatar
I have the QTP 2 piece cover and it is quiet an impressive piece. You can see the man hours it has into it. All CNC billet aluminum. I would not try it any other way. Cutting a stock cover doesnt work IMO. It will weaken the already weak aluminum cast. And the bonus with there cover it works with there larger HV oil pump. Check it out.
http://www.quicktimeperformance.com/Cover/
Old 03-04-2006, 03:11 PM
383ss's Avatar
if you guys want to search, use GOOGLE. click on advanced and you can specify the domain to search so you can search www.ls1tech.com only. it works great.
Old 03-04-2006, 05:49 PM
b727pic's Avatar
+1
Old 03-04-2006, 05:53 PM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
this is an awsome piece especially for the vettes
Old 03-04-2006, 06:27 PM
n20stroker's Avatar
I running QTP cover and I think is awsome. If u like to change cams as much as me its worth every penny.
