Talk me into a cam!!!
Old 03-03-2006, 11:35 PM
aNuBiS's Avatar
Default Talk me into a cam!!!
Here's the lowdown. I already have a cam, its done me good, but now Ive just went to a nice set of heads and I have since added pretty much all the other bolt-ons since.
But after chatting around Ive realized that since I got a new set of heads, plus I plan on installing an U/D pulley at the same time, Id be stupid not to do a cam change. Or moreso It'd be the most opportune time to do so.
SO here it is, there's so many cams out there right now, and I want one thats going to signifigantly show me gains over what I already have. Otherwise Im not gonna change it.
I currently have a TSP231 its 231/231 .598/.598 the heads are patriot stage II ls6 style heads with chambers welded to 59cc.
Im open to any suggestions only major requirements for me are, I dont want to have to flycut my pistons, and it is taken on some trips, I do like some driveability, I have had no complains with what I already got for a cam, in that department, so I dont know if others are any worse.
So here it is, what cam is worth the time/money to upgrade to!!
ps. anything else you might wanna know is listed in my sig, if not, plz ask.
Old 03-04-2006, 03:00 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
What is wrong with the 231? Why not try a 231/237 grind.
Old 03-04-2006, 03:02 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
IF you want big with good reaction to the spray, go with the MS3. But your heads might cause a problem going that big for Piston to Valve Clearance...
Old 03-04-2006, 10:28 AM
2K2WS6TA's Avatar
FWIW if you aren't dissatisfied with the performance of your current cam then why change it? Change for the sake of change is IMO a little silly. On the other hand if you aren't happy with the cams performance then by all means change it out
Old 03-04-2006, 10:43 AM
PREDATOR-Z's Avatar
I would not change the 231 unless I was gonna go BIG, like really BIG.
Old 03-04-2006, 10:44 AM
aNuBiS's Avatar
Like I posted, I wont change for the sake of change. If there is a cam out there that will give me better all around performance over what I currently have, then Id like to change it out while my heads/intake and front pulleys are off. That's the opportune time.
Old 03-04-2006, 11:12 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
A solid roller will give you performance enough for change.
Old 03-04-2006, 11:24 AM
PREDATOR-Z's Avatar
That would be difficult
But if you're willing to sacrifice bottom end for more top then MS3, G5X4 or similar, but (there is always a but), then PTV becomes an issue.
See the TSP 231/231 is the ancestor of the Torquer cam
TSP 231/231 > TSP 233/233 > TSP 232/234 (torquer V2)
{LOL torquer evolution}
Old 03-04-2006, 11:37 AM
aNuBiS's Avatar
Thanks for all the great responses.
Old 03-04-2006, 11:44 AM
nokeman's Avatar
If it will fit go with the MS3...but the cam you have seems like it is great anyway.
Old 03-04-2006, 03:27 PM
aNuBiS's Avatar
Yeh, I would love to see a dyno over dyno difference between my cam and a MS3 or similar. That would make up my mind fairly quick. Or, more importantly, a couple timeslips from each. Im more concerned about 1/4mi performance than I am what its gonna say on a dyno.
Old 03-04-2006, 03:32 PM
Nate_Taufer's Avatar
Why not have something custom ground from somebody after providing all the specifics of your setup to them.
Nate
Old 03-04-2006, 03:38 PM
aNuBiS's Avatar
Nate
Hey theres an option too. Who offers those kinds of services??
Old 03-04-2006, 08:38 PM
nokeman's Avatar
I believe TSP will custom grind a cam for you. If this is not the case please correct me.
Old 03-04-2006, 08:45 PM
bad0211secws6's Avatar
I think you should go with an fm14 from futral on a 112 with no advance.its an awsume cam great driveability and superb torque at all times.my other suggestion would be a lg motorsports cam they are almost as good as the futral in my opinion.
