6.0 block??? cubic inches??
Old 03-07-2006, 10:10 PM
iMpoSStoR's Avatar
Default 6.0 block??? cubic inches??
what kinda cubes would a 6.0 block with stock stroke 6.125 rods and 4.000 bore be?.. since it is a brand new block i will not need to bore it over.. or would it be better to do so??? also will everything from a ls1 switch over or will some stuff need to be modified?...
Old 03-07-2006, 10:13 PM
jrp
SN95 Director
jrp's Avatar
364ci. you'll need to tap an extra hole for the alternator.
Old 03-07-2006, 10:29 PM
408WS6's Avatar
364 cubes? Are you sure?
My 6.0 L motor is 408 cubes and has the 6.125 rods
--> http://i2.tinypic.com/qyy53d.jpg
The bore is 4.030".
I believe that yours would be 402 cubic inches. LME did my block and the block was brand new. But they bored the block anyway. Seems like if you use moly rings you have to re-bore.
Old 03-07-2006, 11:08 PM
ArcticZ28's Avatar
A 6.0 with stock stroke (3.622) is a 364. A 6.0 with a 4.000 stroke is a 402. A 6.0 with 4.000 stroke bored .030 over is a 408. etc etc
You don't have the bore the block at all and a lot of people don't, i.e. a 402.
Old 03-07-2006, 11:18 PM
408WS6's Avatar
Ooops. I assumed stock stroke meant 4.000" which is the stock stroke for a 6.0 L. My bad.
Old 03-08-2006, 07:15 AM
S10slepper's Avatar
Old 03-08-2006, 07:21 AM
slow trap's Avatar
the stock stroke is the same in the 6.0 as it is in the 5.7=3.622,only difference is the bore 3.898 vs 4.000.
Old 03-08-2006, 07:23 AM
PREDATOR-Z's Avatar
stock stroke is 3.622
Old 03-08-2006, 09:24 AM
1Bad RamAir's Avatar
If you need a set of JE pistons and 6.125 rods I have a set that cam out a 6.0l engine. Let me know.
Quick Reply: 6.0 block??? cubic inches??
