PRC Stage 3 Dart 225 flow numbers, independent test
I had Jason from TSP make me a set of Dart 225's with 2.080/1.60 valves, not milled, equipped with their dual springs, etc.
I had them sent directly to Combination Motorsports to install on my 402 shortblock. I was told there was a flow sheet in the box when they were sent out, Dave at Combination said no flow sheet in the box when he got them yesterday. Ok no biggie, have them flowed for me, and he uses another shop (West Coast Racing), and they have ZERO interest in these heads, they work on Supras, etc, so they flowed them and have no reason to f up the data. They use a brand new Superflow Bench 1020.
But here's the breakdown.....
Test Data:
28" of Water
4.000 bore
Valve lift(Intake Side)-
.100 65.30
.200 134.40
.300 199.50
.400 257.80
.500 292.90
.600 304.60
.700 313.40
Valve Lift(Exhaust Side w/o pipe)
.100 56.30
.200 96.60
.300 135.20
.400 175.20
.500 201.40
.600 219.10
.700 225.40
Valve Lift(Exhaust Side w/pipe, 1 3/4 to 1 7/8 stepped pipe)-
.100 55.60
.200 100.00
.300 142.40
.400 186.10
.500 215.30
.600 234.80
.700 242.80
Now, I'm no expert, but I know there are little differences/variations on flow numbers from bench to bench, but is 26cfm down at .600 in that realm of error? I know flow numbers are probably like dyno numbers, they may perform and flow low, but we'll have to see. I'm not mad, I was just shocked to hear the numbers compared to advertised numbers. As long as they make power I don't care what they flow, I know the bigger valves will help me make power.
I DO NOT want to wait on a new set before this motor goes together, I waited 2 months for these heads, and I NEED my car back together. If I dyno low, then I know why. But this is accurate data, true and not fluffed data, and I trust the flow I got. If I had a flow sheet with the heads I could compare it to this and see what's up, but we don't.
Any opinions on these numbers?
Thanks again Jason for getting me the heads, the parts I needed and sending them where I needed them to go. I know you guys are swamped with orders and I appreciate all you have done for me through this tough time. I hope to make 500+rwhp with my setup, and I hope these heads live up to their reputation.
Test Data:
28" of Water
4.000 bore
.100 65.30
.200 134.40
.300 199.50
.400 257.80
.500 292.90
.600 304.60
.700 313.40
.100 56.30
.200 96.60
.300 135.20
.400 175.20
.500 201.40
.600 219.10
.700 225.40
.100 55.60
.200 100.00
.300 142.40
.400 186.10
.500 215.30
.600 234.80
.700 242.80
LS1 Tech Administrator
Good numbers, but they do not raise the bar over existing good aftermarket heads. Certainly not at the level of AFR 225s or ETP heads of similar cross sectional area. They should still make excellent power though.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
So your saying they were supposed to flow 330 cfm advertised at .600"? I understand flow benches have variations, and the 1020's are a bit stingy, but I think the numbers you got are more in line with what I would expect from a 225 cc head on a 1020 bench. I would have been sceptical of the 330 cfm from the begining. There aren't many heads out there that can achieve that goal with the givin port volume. I know a few say they do, but everyone seems disapointed when the independent results come in. Not that TSP is inflating, because they have always been great to work with, but I have flown a few 320cfm advertised heads, and the results were far worse then what you got, and they were from "reputable" vendors at that. I think your numbers are good for a stingy bench. I say roll with um' and see what happens.
I also want to know the final intake volume and the cc of the heads. I already PM'd him, once he gets back to me I will see what he has on file.
LSxGuy widda 9sec Mustang
I remember seeing Jason flow those exact heads with a 4" bore and a good LS1-specific radiused inlet. They flowed 324ish @ .600" lift on our SF600 Flowbench. The flow numbers look in-line at .500" and below, and the exhaust looks right on too.
Precision Race Components Stage 2 cnc ported cylinder heads. Fully CNC ported Dart LS1 based cylinder heads!
NEW Dart Cores
2.02 1.60 Valves
Dart Single Springs Rated to .625" Lift
Completely Assembled & Setup To Your Specs!!
Valve Lift Intake
.100" 74
.200" 153
.300" 209
.400" 260
.500" 296
.600" 320
.650" 324
As long as the heads perform, that's what I care about, and I was concerned about the large gap in the cfm range from what they are supposed to do. It could be the bench, it could be that TSP setup the bench different than the other shop, who knows. If they don't make the power, then another head will go on the car and we'll do it again
Could be a number of things that would throw flow readings off. In my experience the guys at TSP deliver. My budget PRC LS6 heads have performed well, I hope you get great results as well.
Here are independent results on a PRC Dart CNC Stage 2 (2.02 valve). I can't say my buddy is unbiased, because he is a porter and does mucho LT1 / LS1 work, but I did stand there and watch him do it, and no stunts were pulled....
SF600, 28", clay inlet:
Lift Int Adv int
.100 68 74
.200 144 153
.300 207 209
.400 260 260
.500 298 296
.550 312 TBD
.600 315 320
.650 305 324
Only thing I had a problem with here was the .650 number.
Lift Exh (no pipe)
.100 51
.200 92
.300 133
.400 172
.500 200
.600 215
hmmmmm.....looking at Tony Mamo's flow-o-rama (I would ALWAYS ignore ADVERTISED numbers IMHO...), its a good, but not great head.... albeit with a rather large port and somewhat average exhaust flow
Waiting for dyno results from somebody without issues at this point
Oh BTW ...we also flowed an unported Dart 225, which went 313 @ .650, and otherwise matched the published Dart numbers (about 20 cfm down from the intake numbers above, ~more or less)
Lift Int Adv int
.100 68 74
.200 144 153
.300 207 209
.400 260 260
.500 298 296
.550 312 TBD
.600 315 320
.650 305 324
Lift Exh (no pipe)
.100 51
.200 92
.300 133
.400 172
.500 200
.600 215
Originally Posted by 383ss
wow, interesting results. I almost got a set of those 2.08 valve heads. kinda glad I didn't at this point. I'll hold out for 240 or 255 ETP's.
Originally Posted by 11 Bravo
I don't know, I think the LS7's are the best heads out. Of course you still have to find an intake and everything else. I haven't yet seen anything about the ETP's that convince me they are better.
