Anyone have problem w/ .040 MLS Gaskets?
Old 03-13-2006, 08:53 AM
Layn_Low_247's Avatar
Default Anyone have problem w/ .040 MLS Gaskets?
Looking at purchasing a set, just want to check to see if their have been any issues. I know ppl say to check the P/V clearance, where I should be fine w/ a 228R Cam.
On a side note: I'll be running a 11.34:1 CR, anything that I should watch out for there?
Old 03-13-2006, 09:13 AM
MSGHUFF's Avatar
No problems here and I think my cr is the same or just a tad higher. make sure to check how much your pistons come out the hole mine were .006
Old 03-13-2006, 11:25 AM
ROCNDAV's Avatar
Originally Posted by MSGHUFF
No problems here and I think my cr is the same or just a tad higher. make sure to check how much you pistons come out the hole mine were .006
Yes, this is true. I didn't do this and I found out that my block had been decked. With .040" cometics, I had around .025" squish, so I had to go with .051.
Measure your piston height out of the block.
Old 03-13-2006, 11:58 AM
What's the standard rating for piston height on our LS1s? I mean I don't see any of the mods I've done to date changing that height.
Old 03-13-2006, 12:09 PM
ROCNDAV's Avatar
I think the OEM height os .007, but I guess any where from .005-.008 is norm.
Old 03-13-2006, 07:06 PM
ttt
Old 03-13-2006, 08:22 PM
Ksett's Avatar
MSGHUFF, what cc are your heads at?
Old 03-13-2006, 08:51 PM
MSGHUFF's Avatar
Milled .030 so ~60cc
