What to do about coolant on initial startup 408?
So when I did my cam change before I just left the radiator cap off and filled the radiator as the engine pulled it into the block by way of thermostat.
Now, for a new block/heads that have NO coolant in them, is it ok to just do the same thing? Fill up the radiator , start it up dry, and let it pull the coolant into the block as it needs it by way of temp of thermostat.
Or do I need to somehow prime/fill the engine block with coolant?
Thanks
ALMOST READY TO START
Thanks
I wondered the same thing with my engine I ended up starting it dry, and filled up the radiator as the coolant went down. I didnt have any problems with it, and havent after about 1500 miles *knock on wood*
Hi on my 408 just add coolant to the tank, i managed to get a gallon and a half in let it sit a few minutes and keep adding untill it want go down anymore then when you start up just keep an eye on the level and add as required.
LS1 Tech Veteran
If you want, fill up the coolant as much as you can and pull the hose from the vent line that enters into the throttle body and stick it (or better yet a longer hose) into a coolant jug. Then start the engine and as the water pump pressurizes the engine, the air will be purged out and the coolant will get into the heads. Once the engine has run for a few minutes, connect the hose in a normal way to the throttle body and add coolant again. Most of the air will be purged and the coolant will open the thermostat a little quicker on the next start.
Even if you don't do anything special on the first start-up, once you've topped off the coolant several times as GEN III advises and all should be well.
Steve
Steve
Steve
Steve
Thanks!
We are required to use an SPX coolant refiller on all our cars at work when we drain the coolant. you shove the tool in where the cap goes. Hook it to an air hose and it pulls a vacuum on the cooling system. Then take the fill hose from the tool and put it in a bucket of coolant. The tool fills the system to the proper level without any air pockets.
Like this one
http://www.shop.com/op/aprod-p22261939
Like this one
Another way is remove the thermostat. Start it and let it run for about 15 seconds.
That will fill all passages immediately.
Put the thermo back on and follow regular procedure.
Originally Posted by 99whitews6
Nice... probably will be doing that! Would it be alright to just keep the thermo out for the first idle running cycle(~30 minutes)?
Yeah, but I would just put it back on. The motor will be having enough problems as it is to find idle and the PCM will be doing all kinda learning. It is better that it reads as close to normal feedback from the sensors.
What about removing the stat and just pouring coolant into the pump until it wont hold anymore, and then put the stat back in and call it good? Maybe it will work its way into the block and it wont be completely dry!
Look all of this is not necessary unless you do not trust that the Thermo will function properly.
Running dry will not harm anything. Just keep your eye on the temp. In any case i would run a 160 in there.
You can tell if your thermo is working because the hose will be hard to squish when closed, once it opens it is much easier.
