going from a 1.7 to a 1.75 comp rocker?
Old 03-24-2006, 03:51 PM
JRracing's Avatar
Default going from a 1.7 to a 1.75 comp rocker?
I am doing a H/C swap on my car and I was told to use an adjustable rocker arm set up to get all the lifter preloads set correctly. Due to differant ptv clearances on each cylinder.
Well I found a used set of comp pro magnums that are 1.75 ratio is the FS section and was wondering the differance in ptv clearance with running the 1.75.
The cam is a 591/601 lift. Do I divide the lift by the 1.7 and then multiply 1.75.
If so my new lift would be 608/618 is this correct.
If so, I may have to flycut a little more on the intake valves. as I only have .080" right now with the stock rockers.
Old 03-24-2006, 04:55 PM
WhiteRhino's Avatar
Yep,your math is correct.As far as fly cutting I dont know.
Old 03-24-2006, 05:08 PM
JRracing's Avatar
If this is correct, I will need to cut another .017" off of the int side of the piston. I have .080" PTV clearance right now and want to keep it at that.
Old 03-24-2006, 06:46 PM
JRracing's Avatar
>017" it is. I just bought the rockers! More lift = more power right?
Old 03-24-2006, 06:53 PM
BOTTLE ROCKET's Avatar
JR
What's involved in installing these rockers? Several aftermarket rockers require that you use valve cover spacers or do some grinding on the covers. Are these going to require any modifing to run?
BTW, If you decide not to use them, I've been looking for a set for a few weeks.
Old 03-24-2006, 07:30 PM
JRracing's Avatar
Originally Posted by BOTTLE ROCKET
JR
i think they will need spacers. Witch will not bother me any. I just painted my valve covers red with the coil brkts. My **** will be bling bling with my freshly painted fast int.
Old 03-24-2006, 07:38 PM
JRracing's Avatar
Old 03-24-2006, 11:01 PM
Unaffliated Racing's Avatar
No spacers.....just a bit of clearencing inside the valve cover.
Old 03-25-2006, 02:28 AM
JRracing's Avatar
What? A littile bit of grinding0 or what? On the inside of the valve covers of what?
I can handle a little bit of that.
Old 03-25-2006, 06:16 AM
SAM98WS6's Avatar
you will have to clearance the valvecovers...no matter what the ads say..
Call comp to get recommended preload. usually .008-.010" cold using a dial indicator...but i dont know you lifter.
Old 03-25-2006, 07:54 AM
Viper's Avatar
LS1Tech 20 Year Member
Sam98Ws6
As you and I discussed, that preload sounds like it's for a comp r lifter.
As you said, call to be sure.
Old 03-25-2006, 10:14 AM
JRracing's Avatar
I have the comp 850-16 OEM style lifters. What should the preload be? Thats one thing I'm not real clear about.
Old 03-25-2006, 10:15 AM
JRracing's Avatar
We were going by .030". Is this not correct????
Old 03-25-2006, 10:16 AM
Viper's Avatar
In here:
https://ls1tech.com/forums/showthrea...t4487617&conly=
Old 03-25-2006, 12:25 PM
JRracing's Avatar
Thanks thats some good info.
Old 03-25-2006, 08:19 PM
SAM98WS6's Avatar
you need to call comp.
Old 03-25-2006, 08:22 PM
JRracing's Avatar
I think I will just to see what they recomend.
Old 03-27-2006, 08:53 AM
JRracing's Avatar
I'm using comp 850-16 lifters as well.
Quick Reply: going from a 1.7 to a 1.75 comp rocker?
