Stock Springs Torquer2
Old 03-28-2006, 06:51 AM
dameter21's Avatar
Default Stock Springs Torquer2
Do You Guys Think It'll Be Ok If I Drive A Car With Stocks Springs With The Torquer 2 In It, I'm Putting The Cam In My Self But I Don't Have A Compressor Or More Performance Or The Like Spring Tool, I Need To Drive It 50 Miles To The Shop, To Have The 918's Put On.
Old 03-28-2006, 06:59 AM
PREDATOR-Z's Avatar
Hell NO !!!
Also if you use 918's you better shim them to .100 coilbind.
Old 03-28-2006, 07:12 AM
dameter21's Avatar
How Much Do You Think A Cam/ Spring Install Would Cost, I Hate Paying Cause I Know How And Have Did It Before, But I'm Far From Home ''texas'' And I Don't Have My Tools. I Live In Northern Virgina.
Old 03-28-2006, 07:17 AM
GuitsBoy's Avatar
I hope youre talking about suspension, cause theres no way your valve springs would handle that cam.
Old 03-28-2006, 07:19 AM
GuitsBoy's Avatar
Buying a cheap socket kit and a $30 valvespring compresor will be a hell of a lo cheaper than the cost of an install.
Old 03-28-2006, 08:59 AM
snketr's Avatar
Or drive to the shop to have the springs changed before you do the cam install.
Old 03-28-2006, 10:50 AM
PREDATOR-Z's Avatar
Bingo
Old 03-28-2006, 11:27 AM
nokeman's Avatar
Dude there is no way you can use tha cam with stock springs. Use PRC duals
Old 03-28-2006, 11:40 AM
93TAWicked1's Avatar
You don't need a compresser, just a 30 dollar spring compressor and use the TDC method. I didn't even take out my spark plugs. Yeah its a PITA but it works perfect. You'll save 200 bucks on labor. Just go to LS1howto's and follow the tutorial its easy.
I will say this though I'd spend that 200 on a used aircompressor it makes the entire job MUCH easier.
Old 03-28-2006, 01:48 PM
TTU98SS's Avatar
best idea ^^^
